oh and this is for a RB20 just want to work out the final numbers. im building the engine for drift so want good mid range response and as much top end as i can. new red line is 8500. 4k and below i dont care about. if i will make more power with an 8.2:1 with 25psi that would be better, im just not sure how that all works
Boost is not your friend, airflow is.
If you are serious about building such a motor start googling and learn how to read compressor maps.
You will see that the most you would want to run is from around 18-22psi absolute max.
I wouldn't go below 8.5:1 personally.
See the Y axis PR value of 2
That is 15psi.
2.5PR is 22psi. As you can see this is nearing the top edge of the compressor map. The center island within the map is where the turbo is most efficient.
Do engine airflow calcs and plot RPM's on the graph.
At high rpm its best not to have the engine airflow heading out of the map (to the right obviously) as you will enter the choke zone. The choke zone is where the turbo is very bad at pushing air. Not efficient. This is what people mean by keep pushing boost in to it until it doesn't make any more power.
At low rpm you don't want it to be boosting to the left of the map as this is the surge zone.
Its a little complicated to workout the airflow, but not impossible.
You need to take into consideration air temp, intercooler efficiency, volumetric efficiency etc.
22psi will run in to choke at higher rpm's.
I'm trying to explain it in lamens. :P
Imagine plotting on the graph, as rpms increase at a certian boost level the engine consumes more air, i.e the plots will slowly move to the right.
Running a constant 22psi right near the edge of the map, the turbo is able to flow less air than a PR of ~2.3 or 19psi.
So theoretically you will be better off running 19psi at high rpm as it will get you the most out of the turbo.
I'm not 100% on all the comp maps etc but I do have a rough idea. There's still a few things I don't understand 100%.
i was just wondering if anyone knows what psi range a Trust TD06-20G is rated at.
currently have same turbo on my Rb20 and i have had it running slightly over 1.5bar with out a problem. (engine has been built to cope with this though) i would suggest that if your serious about building a drifter and if you have ever tried to drift then you would know that anything over 18psi is just asking for trouble really.
Aim to build the car so that you can hold around 14-16psi and the rev range will depend on how hard you want to push it and how often you hit the limiter.
If you want any info or looking for something then send me a PM as we might be able to help each other out???
Cheers B
The engine very well may be still within the compressor map at 1.5bar on the rb20.
Slap the same turbo on a rb25 and it may be stepping out side of the map at only 1bar.
You really need to do engine airflow calcs then work out what what the X-axis values on that damn compressor map are in.
hhmmmm ive never had a problem. running over 20psi
i never said you would have a problem running over 20psi did i. I said why would you want to run that ofr drifting :confused:
If you have to be running that sort of boost then you have to be extremly high up in the rev range for drifting which to me just doesn't seem the best option!!!
I could be wrong but if you look and talk to most experince drifters that do it for al iving they will tell you the same thing. You will find that not many of them would be running over 14psi.
But thats just my 2cents and happy drifting at 20psi :crazy:
nah buddy, no crankiness. It was bed time when I wrote that last post so it was short and sweet so to speak. :P
When I have some time, out of my own curiosity I will do the rb20det's airflow calcs and plot them on the compressor map. I still think the TD06 is one of the best matches to the rb20det, with the right exhaust housing that is. :)
The boost you run is irrelivent anyway. Its the power you make that matters.
Slap that same turbo on a RB25DET and you will find to make the same power you will need around ~6psi less.
Thee's also the reliability issue of running such high boost all the time, not so much the engine but the poor old bush style turbo that requires rebuilds every 40,000km's, and thats with a fairly normal life, not 25psi. :P
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
