Ok people maybe I missing something here.. but like how do you do a burnout :rofl: ?
I've tried the hole revving her then quickly braking thing.. the car just hops along as if the brakes are to strong or something..
I went to calder for the first time tonight, and god its embarassing not doing the hole burnout thing before hand :) Never realy anoyed me until now (due to the fact I hadnt been to calder b4) So I need detailed instructions on how exactly to do it please.
Also I know doing burnout before race wont realy affect my car/tyres since it isnt exactly a a full on drag car, but its pissing me off now that I cant.
question>
thanks heaps ppls :)
https://www.sau.com.au/forums/topic/81464-burnouts/
just disconnect your rear brakes or get some sort of line locker and go nuts :rofl:
but this is generally the order
1) rev it to about 3k (depending on power of your car)
2) drop the clutch
3) get it revving around 6-7k
4) quickly introduce the brake pedal but only do it enough so you dont move
5) look in the rear view to see the smoke billowing out ya ass :)
https://www.sau.com.au/forums/topic/81464-burnouts/#findComment-1479645
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
