Just Jap is pleased to continue to offer these unbeatable deals on our massive range of universal intercoolers
We have 1000's of these intercoolers in stock, in a variety of sizes to suit any application - and all are ready for immediate pickup & dispatch, so unlike other deals floating around the net, there is:
1. No deposit required
2. No minimum order
3. No waiting
4. Easy online payment options
5. No surprises
Deal with an established and trusted company! - Not a backyard trader
ALL INTERCOOLERS INCLUDE A 12 MONTH WARRANTY
JUST JAP IS AUSTRALIAS LARGEST INTERCOOLER DEALER AND DISTRIBUTOR AND WILL NOT BE BEATEN ON PRICE!
1000 INTERCOOLERS IN STOCK AT ANY ONE TIME
Picture of the 600 x 300 x 76mm Intercooler - High Quality Bar & Plate Core (Available with 2.5 or 3 Inch Inlet/Outlet)
$175 DELIVERED AUSTRALIA WIDE
450 x 300 x 76mm Intercooler - High Quality Bar & Plate Core (Available with 2.5 or 3 Inch Inlet/Outlet)
600 x 300 x 70mm DELTAFIN Interooler - High Efficiency GT Type Core (Available 3 Inch Inlet/Outlet Only)
NEW STYLE - JUST ARRIVED!
$185 DELIVERED AUSTRALIA WIDE
600 x 300 x 76mm Intercooler - High Quality Tube & Fin Core (3 Inch Inlet/Outlet)
$195 DELIVERED AUSTRALIA WIDE
Picture of the 600 x 300 x 76mm Intercooler - High Quality Bar & Plate Core (Dual 3 Inch Inlet/Outlet)
600 x 300 x 100mm Cooler - High Quality Bar & Plate Core (Available with 2.5 or 3 Inch Inlet/Outlet)
$275 DELIVERED AUSTRALIA WIDE
* Further discount available for bulk orders shipped to a single address
So how do you take advantage of this fantastic prices??
The answer is simple!
Visit www.justjap.com/forumcoolerspecial.htm and purchase your intercooler online quickly and easily via paypal or credit card, or drop by our Kirrawee factory and pickup your set over the counter.
Please contact [email protected] if you have any questions, or reply here.
They are selling very fast so be quick
Dont forget to check out our huge range of new and used performance parts and import vehicles via our website at www.justjap.com
  • Replies 161
I require an IC that has the inlet/outlet located in the center of the core.
Are any floating around that you know of?
Not at the moment sorry
Last Temptation - Easy!
Email [email protected] and he will provide you with direct deposit details.
As soon as payment is confirmed we can have an intercooler on its way to you.
Thanks for the support guys
_8005TED_: I just replied to your pm, your order is confirmed and will be sent out asap.
Steve
Hey Steve
Im interested in one of your intercoolers
are they still available ?
I'm wanting the 600X300X76 too
Thanks
Barret
we have heaps go ahead
Steve
Just ordered online tonight one medium cooler and one baby turbo timer what time frame am I looking at for delivery I'm in Brisbane?
Thanks
Chris
Hi Chris, thanks for your order - Your payment has been confirmed.
I would anticipate that you will receive your intercooler and turbo timer around Wednesday this week.
Thanks also to the rest of you who have ordered intercoolers today - we have plenty of stock remaining for others that may be interested.
Thanks
Steve
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
