  • Replies 161
whickh one is suitable for an r32 with an rb20det in it?
Hi Roland, the most popular size for an R32 GTS-T is the 600 x 300 x 76mm
Regards,
Steve
hey another question. your piping kits for the r33 gts-t, i have the stock plenum chamber so i just wanted to make sure it was designed the standard position not next to the engine with aftermarket plenum chambers. Also i want to keep a plum back bov on for legal reasons so is the piping suitable for a plum back with an entry point or only atmospheric.
Thanks for your help
The factory cast pipe with the factory bov stays in place with our piping kits. These kits are also designed for use with the factory plenum.
Cheers,
Steve
ow sorry and to add to that atm ive still got the stock exhaust manifold and low mount stock turbo. Will the piping be suitable and when it comes to upgrade will i need to buy new piping to fit a bigger turbo or top mount
You may need to change piping if you fit a large high mount turbo, but if you simply fit a larger turbo in the factory position there shouldnt be any problem
Steve
you just seem to have all the right answers lol. i like that
All pm and email enquiries now replied to
We have another 1000 coming shortly.
Cheers,
Steve
Hi mate, thanks for your enquiry
We have plenty of stock still available
You can place your order online at the URL below:
http://www.justjap.com/forumcoolerspecial.htm
Cheers,
Steve
hey i was just wondering how long they usually take to get to W.A?
Hi Massey, we normally say allow 3-4 business days for delivery to WA.
Cheers,
Steve
Another question. I am interested in the medium size cooler for my R33, however i would like you to confirm that the piping kit would be suited to the smaller cooler.Is there a compatible piping kit for the smaller cooler?
Thanks
Peter
Thanks
Peter
Hi Peter, the 600mm intercooler is the best size for an R33 GTS-T as as such the piping kits are designed for use with the 600 x 300 x 76mm intercoolers.
Regards,
Steve
hey there...i just placed my order for the 600*76*300 cooler to 2774...thanks ;))
Thanks for your order Chris :)
Your order has been confirmed and your payment received. Your cooler will be sent out tommorrow
Cheers,
Steve
Hi Richo, thanks for your order. Your payment has been received and confirmed and your intercooler will be sent out shortly.
Regards,
Steve
I want to fit one of these intercoolers to the front of my 4.2 diesel Nissan Patrol. I think that the bigger IC would suit best but need to make sure that it will fit.
I assume that the dimensions listed are for the core only. Could you please post the overall measurements including the end tanks for the medium and large JustJap coolers?
Thanks in advance!
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
