Creative I-Trigue 2200 Speakers
A brilliant mix of performance and style in this contemporary 2-piece speaker system brings you pleasant listening everyday. Designed to flatter your notebook, LCD monitor or portable audio device, the Creative I-Trigue® 2200 Speakers are artfully presented in subtle curves and stunning finishing. An eye-catching duo, the two speakers come with built-in 36mm NeoTitanium micro drivers and a rear bass port for impressive stereo sound quality and refined lows.
Near new condition $60 Delivered
Linksys Wireless-G Notebook Adapter
-High-speed Wireless-G (802.11g) networking for your notebook computer
-Data rates up to 54Mbps -- 5 times faster than Wireless-B (802.11b)
-Also interoperates with Wireless-B networks (at 11Mbps)
-Advanced wireless security: Wi-Fi Protected Access™ (WPA), and up to 128-bit encryption
Brand New $50 Delivered
Linksys Wireless-G PrintServer for USB 2.0 *SOLD*
Direct Deposit Preferred, but can do COD on buyer's expense
Thanks for looking.
Edited by Lezzare
https://www.sau.com.au/forums/topic/82028-fs-linksys-and-creative/
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
