Hi I have the following parts for sale from a R32 GTS4 Skyline, all prices plus freight.
Parts are in Brisbane, :
Left hand headlight - bug eye version, perfect condition - $80 ono..REDUCED
Front driveshafts left and right- SOLD
Front propellor shaft (connects gearbox to front diff) - $50 ono..REDUCED
Front subframe - $115 ono. REDUCED
Front swaybar - 21 mm, same as GTR - $65 ono.
Front hubs - with curved upper link, no discs. - $150 pair ono.REDUCED
Steering rack - in good condition, tierods feel good. - $220 ono.SOLD
Rear subframe , subframe bushes removed!, this is the most expensive/time consuming part done already. ready for new bushes - nismo/Noltec. - $195 ono.REDUCED
R32 GTS 4 RB20DET - silver top, from GTS4. block, complete head, inlet manifold, injectors & coilpacks, good condition. Was intended for RB24 rebuild. Spare incomplete head with only half valves - good to practice head grind on. - $475 ono. SOLD
R32 GTS 4 Gearbox, 5 spd manual with transfer case. In good condition. - $575 ono. SOLD
Stephen
P.S. suspension parts/light/driveshafts are the same as a GTR.
Edited by gts4diehard
front driveshafts look in good condition. cv joints feel okay, when rotating thru full range of movements by hand. looks to be original cv boots on shafts. splines are straight. bearing in front hubs feel good, so dont think the car they come off has done too many kms. Shafts are leftovers from a front cut.
Stephen
same dimensionally, they look exactly the same but not they do not have the same ratios inside, due to the larger amount of torque that gtr has. could give an acceleration improvement I would think...
Stephen
mate, the incomplete head, does it have lifters in it, and what sort of condition are they in? ie. not rattling or leaking down?
would you be willing to sell them seperatly, and for how much.
Cheers
Ive got a stuffed rb20det head with everything, bar the exhaust camshaft, and 2 exhaust valves....
lemme know what u want for it by pm, otherwise it goes in the bin :cheers:
does the front sway bar bolt on to r32 gts-t ?
im also lookin for a 32 gtr rear sway bar if anyone has one.
thanks ;)
dorry not sure about that. the bars on gsts and gts4 attach differently to front hubs, but they may be the same bar with diff end fittings which could be removed and swapped.
Stephen
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
