  • Replies 275
Posted Images
7heavn: Why don't you have the R32 anymore?
Brad: What's with the OMG? It's not like you haven't seen a huge burnout pic of the 200 :rolleyes:
Adam: What was JETT's mph?
Definitely can't wait for the next one. The rotor guys are also pleased with the day and are eager for another day.
forall those interested,
JETT got towed straight to workshop with potential spun bearing,
1st run) was 11.1 @ 129mph without gas and 7000 rpm launch
2nd run) was 8500rpm launch with gas engaged but forgot to put it back into 4wd from rwd burnout, think maybe did some damage there bouncing off the limiter in 3 gears
3rd run) everything was ready but after burnout heard a knocking so limped it down the track for a 28second pass, my new personal best,
So now jett is at workshop getting rebuild and selling with new internals, if anyone interested in buying after reuild let me know, price will be reasnable.
Jett did at least one 11.1 before breaking.
I just couldn't get proper smoke happening or good launches.  Crap 60 footers and no smoke burnouts don't make for good pics I guess.
I told you mate, you have to step on the brake to stop the car moving forward to do a burnout. You can't just step on the gas and hope it stays in one spot.
We should get Adrian to give SAU'ers lessons on how to do burnouts, because considering that you were told in no uncertain terms that you could burn the entire length of the track if you felt the need, 99% of the burnouts done by SAU'ers left a lot to be desired :chairshot :bonk:
Guest DIRTgarage
That's a bloody awesome time - congrats to all involved with the car.
I actually had one run against you and I felt like I was standing still when you passed me half way down the quarter. I have to say that I now have an even greater appreciation of the raw speed of a legitimate 10sec car. That thing is a machine :rolleyes:
Thanks brendan.......i was thinking as i was roaring past, how bloody good would that sound, a 10 sec car screaming past at full noise.......i think awesome summed it up.
A huge thanks goes to our tuner Jim Souvas, who took time out from being with his family to attend....also a big thanks to Tom Miyamae our suspension expert. The boys from Croydon Racing Developments have helped in taking this car to the next level of performance....10.3 is a great achievement for what is essentially a home built car. Further development in key areas will hopefully see DIRT/CRD with an RH9, 2530 powered GTR.
i sat on it heaps of times merli !!
but just not alot smoke! gotta be the tyres, i left the day with the same amount of tread i started with.
does the beemer sit on the brake?
also wouldnt mind seeing your pics from the day!
Nope... Those 19" Pirellis are waaaaaaay too expensive to abuse like that :rolleyes:
Someone donate an R32 GTR for me to play with :uh-huh: :uh-huh:
Hey Andrew, where are your pics.... i would be certain you got some awesome pics you could share with us all :rolleyes::D
here is a small vid of the 200 if anyone is interested.... you can faintly here Merli telling Andrea "now thats how you do a burnout!!!!!" hehehe
http://members.iinet.net.au/~ferry/videos/...x_rb26_11.8.wmv
I hope that works by right clicking on it...
I'd also like to thank Adam & those who helped organise the day. It was awesome.
A Short vid of my PB 12.158sec @ 110.89MPH
You'll need the Xvid Codec to view it...
Not bad for an old mans car eh :unsure:
Go the all wheel drive.
I think I'm going to have to find a carpark to practice in :P
I think I'm going to have to find a carpark to practice in :O
I think I'll have to do the same thing next time. I've never really attempted 'burnouts' in the Skyline before and was only getting the hang of it by the end of the day :D
So, are there anymore pics/vids from the day? Seemed like there were a heap of people taking pics at the track, but I haven't seen that many posted up as yet :O
Guest DIRTgarage
I think I'll have to do the same thing next time. I've never really attempted 'burnouts' in the Skyline before and was only getting the hang of it by the end of the day :O
im gonna get some burnout training...cant stay off the limiter in 2nd...may have to try a 3rd gear burnout. Stood next to brad after his and his tyres sounded like flypaper....very sticky indeed!.
The quest for 9's
Car has 6 more psi to be dialed into it = more power. Have lined up a HKS ETC-EDA for more front drive, and have a spare transfer case to get modified to 12 clutch plates instead of 7. Didnt think i'd say this but "we will run 9's in this car"
your going to need a 4WD controller so you can make it a 2WD for the burnout Paul.... i dont know if its the right thing for a car such as yours, but a toggle switch would be ideal.... once its in 2WD the burnout will come really easy. I wouldnt suggest dumping it in 3rd as i think thats what has damaged the clutch in the 200 :O:( will find out soon enough though....
Once it gets more boost and a tune you will run 9's and it will be great to see it happen :O:) You just need to teach Stacey how to drive the car harder :D:)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
