if your intersted in pics please let me know ..
Nissan Turbo - Steel Front Wheel - Ceramic Rear - Great Condition $300
I was told it was a VG30 ball bearing.. but few things yet to be confirmed what it actually is ..but i'll find out ASAP :confused: :confused: Found out that it is a RB25 Compressor Wheel and Cover - with a VG20 Rear Exhaust wheel and housing .... good for around 210rwkw on a RB20 ... nice upgrade for cheap.... need to sell .... .. with lines 350 i'll pay for postage
also FMIC 600x300x76 intercooler... slight damage to the mounting points.. but no core damage.....hybrid bar and plate design ... 160 including postage....
http://www.outlawconnection.com/angryaussi...unk/cooler2.jpg
http://www.outlawconnection.com/angryaussi...unk/cooler3.jpg
http://www.outlawconnection.com/angryaussi...unk/cooler4.jpg
RB25 Water and Oil lines ....$50 .. (no banjo bolts)
RB20/25 Exhaust Manifold - Primed in Grey - $60
RB20 Cross Over Pipe.... No BOV version from R31 Redtop $40
RB20 Cross Over Pipe - with Factory BOV - $50
Standard R32 GTR Camshafts - $250
Standard R32 GTR Conrods - $250
Standard R32 Fuel Rail - $50
Standard R33 Yellow GTR Injectors x6 $300 SOLD Pending Payment
Let me know ..pick up prefered.. postage can be arranged for interstaters at there own cost.
email me on [email protected] or PM me
Im located in Hoppers Crossing - Victoria
Thanks
Matt
https://www.sau.com.au/forums/topic/82623-gtr-parts-vg-bb-turbo-rb20-bits/
pics added of fuel rail and injectors... i'll get around to taking pics of the rest of the stuff shortly
injectors are in good condition i bought them over 12months ago ..and i my project has pretty much not eventuated.. 17year old car with 17year old hereit problems to fix.
anyways far as i can tell the "squirting" pentils of the injectors are clear of any junk or build up ..so they pretty clean... i was going to get them cleaned when i needed them for my redtop rb20 ..but project plans have changed.
thanks
Matt
That doesn't look like an rb25 compressor, more like an rb20 but not.
Thanks
Matt
bump
thanks for that completely pointless post .."booster"
have more pics if anyone interested wants to see
http://www.outlawconnection.com/angryaussi.../r31/vg30_2.jpg
http://www.outlawconnection.com/angryaussi.../r31/vg30_3.jpg
its much the same as the turbo that Waldo is selling currently on the forum, same exhaust housing just not painted red. ;)
Comes with Std Dump Pipe and O2Sensor.
Purchased from JustJap earlier this year - told VG30DET Single turbo - Ball Bearing Center - Ceramic Exh wheel- Steel Compressor... unsure wheither its one or the other... either way its bigger than a RB20 standard.
Matt
bump
Matt
Not pointless
In your first post you said a few things are yet to be confirmed.
I'm just offering an informed 2nd opinion for what it's worth.
It is not an rb25 (45V) compressor housing and it is not rb20 but shares the 16V compressor housing so i suspect it came from another 2L motor like the vg20.
Rude pms are not necessary
my apologies... but its not a VG20 turbo .. its too big... simple as that... Cef11E had this same style of turbo on he';s RB20 Cefiro ..
casting marks are the same as what waldo is selling ...04U on the snail
Vg20 turbos did not have 16v 10 on there turbo comp covers.... they are much older than that ....
one that ive seen has 16v 7
Matt
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
