Hey ppl
I put new turbo in my car ITS brand and front mount, and went to test drive the car and car just shudders and goes nowhere as soon as it boosts over 3000 rpm, mind everything is standard apart from catback exhaust and pod filter...guy at workshop that fitted turbo says fuel pump cant cope with the power turbo makes. For reference this turbo made 320hp at wheels on 10psi, 360rwhp at 15 psi and 410hp at 18psi and on my car its set at 13psi and thats set by wastegate...so my question is does this above happen when fuel pump cant cope, and which fuel pump should i get for 350hp at wheels and are warlbro pumps any good...by the way im putting new clutch today (9 button ceramic extreeme brand), getting batmbl split front pipe and cat on monday and getting it tuned next week with wolf 3d plug and play computer so any thoughts are welcome...
regards
Goran
https://www.sau.com.au/forums/topic/82889-r33-modifying-questions/
Problems in order as i read them.
1) Your running a bigger turbo with stock dump,need the bigger one fitted.
2) Your running a stock ECU and 13psi from a bigger turbo? Major problem
3) your running stock injectors, you'll be on the limit of thier usefulness and will need to upgrade IMO
4) You will also need a bigger fuel pump, walbro's are junk
put all your bits on, get a fuel pump then see how its all performing then.
You have too many things that you will address, and need to before a better answer can be given.
Why are Walbro's junk ? Less than claimed output, or longevity etc ??
Gary
on my car we were using it and around 250rwkw it the AFR's werent looking so good.
We then decided just to use the walbro as a lift pump and then use a Bosch pump with the surge tank.
At time of installation of the surge the walbro was checked to make sure it hadnt moved in the tank and it was fine.
Had upgraded power etc.
Back onto dyno... surprise surprise. AFR's totally different = rich as. I wasnt impressed thats for sure and im not the only person.
Search button is your friend
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
