For sale: 1989 180sx ***
Asking Price: $16,000 ***
Engine Type: Ca18DET to 2.0 ***
Complianced: no
Road Worth Certificate: no
Registration: no
mods
ca18 det to 2L
5 speed manual
Aftermarket Parts:
HKS 2.0 stroker kit (HKS Pistons, rods and crank)
Tomei cams gears (possibly cams as well)
Kei office Coilovers front and Tein HA Rears
Twin layer radiator
ARC front intercooler 108 thick with all new piping
Jap Oil cooler with remote filter kit
Apexi Style Pod
Defi style boost guage, Blitz water temp and oil pressure guage
Oil catch tank
5point half cage
Earthing kit
Push engine starter
Master cylinder stopper
Nordi steering wheel,
Shift knob,
FET turbo timer
GT wing
TD05 kit with Trust 48mm external wastegate
z32 afm
re map e.c.u from jap
Mechanical LSD
injectors 550cc
OS Giken twinplate clutch
fuel pump
3' Exhaust Systems
think thats all the mods
make 194rwkw on 1 bar with a base map
i have had it hear for 2months i have put a lot of new things on the like the cooler/ turbo kit , exhaust and more i have spent about 5k on i since landing
Pics can be found at http://www.nissansilvia.com/forums/index.p...howtopic=104981
Can you provide any documented proof of the stroker kit?
Going off the pictures on ns.com, when you got the car it didnt have the TD05 kit, what turbo was it running exactly?
The car was using a T28 S15 BB, it was an abandond project in Japan so they slapped a T28 on it and just a ARC cross pipe cooler and a safe map and sold it off.
The engine work was performed in Japan unsure of the garage. The previous owner stated he had put a HKS stroker kit in the car and judging by the toqure this car procduces and the way the curve runs, this backs up his claims. Also at MAS this car made 50more dyno nm of torque than a SR making 20kw more
I will post the dyno pic as well.
Also the car is being retuned currently and shold see 215rwkw on 15psi.
Here is the 194rwkw Dyno sheet, this doesnt really show what iam talking about, ill dig up the other sheet for 184rwkw. that backs up my claims.
Dont bet on it.
I recently sold my 180sx, with a similar setup, TD05-16G turbine kit and it made around 180rwkw on the 1.8.
I will have to look and see if I can find my dyno sheet
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
