Hey Peoples
I have a Blitz Super Sound BOV Kit which was installed on my R33 but i've recently installed an aftermarket intercooler on the car and can no longer use the kit. I would like very much to install a new bov, preferably the Apexi Super Sequential BOV. Would anyone consider a trade for that and / or something else...
LET ME KNOW....
Cheers
Guesty
https://www.sau.com.au/forums/topic/83055-bov-swap/
Hey Peoples
LET ME KNOW....
Cheers
Guesty
Hey i have a Turbosmart Type 3 Supersonic BOV im willing to swap if your interested. I want to swap it because i need one that isnt so big.
You can ring me on 03 5335 9168 if your interested
https://www.sau.com.au/forums/topic/83055-bov-swap/#findComment-1504344
i have the apexi bov. But the red ring used to change the release holes has been sanded down to make it less noticable. Can you throw in the cooler pipe aswell?
Hey
What do u mean its been sanded? I dont understand... Is it the Super Sequential BOV, cause thats the one i want. Is it loud or does sanding it make it less noticable sound wise? could u send me a pic, my email is [email protected]
Im very interested...
Cheers
Guesty
https://www.sau.com.au/forums/topic/83055-bov-swap/#findComment-1505438
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
