Selling my R34 due to financial commitments.
R34 GTT- five speed manual
Immaculate original condition
Original 40000km
One owner car in Japan, and im the first owner in Australia
3.5inch catback HKS exhaust system
Factory standard Nismo bodykit
Originally no rear spoiler
Custom number plates GTTR34
$1600 alpine stereo system
Never been boosted
PRICE DROPPED:
$33000
Like i said earlier this car is in absolutely immaculate original condition and the only reason im selling it is due to the fact that im moving out in Novemeber.
PM me for more details or
I can be contacted on 0408058064 or [email protected]
Edited by mick34
https://www.sau.com.au/forums/topic/83599-immaculate-r34-gttmelbourne/
ill swap you a black 1998 r34 gtt tiptronic with blitz fmic 3inch exhaust apexi pod filter. also serviced religiously every 5000 using motul oil.
hehehehe
i know you are wanting a cheaper car with cash change over but hey i thought id ask anyways as i am looking to replace mine with a manual.
hehehehe
Yeah it was worth a shot but sorry mate i really need the cash so ill only swap for a cheaper car.
Edited by mick34
These are the 18s i can through in although im not willing on selling them seperately, only with the car. Car without the rims now price dropped to $36000
What are the 18s? Got pics? May be interested in buyin...
Edited by mick34
I just bought a mint 2001 R34 GT T with only 27,000 ks. Car came with Tein Coilover suspension with EDFC, HKS Turbo back exhaust, brand new Apexi turbo timer & brand new alarm/immobilizer for $28,500.
Good for you buddy..i really doubt you did though and if you did its probably been written off and reparied in Japan as the 2000 and 2001 models in japan go for nearly 2mil yen.......How about you read the rules before posting. If your not interested in this car DONT POST!!!!!
This car was a grade five auction grade .... no accident history and original log books so ORIGINAL K's.
ahhaah dude, whats he gonna do with a missin front bar if he sells it.. stupid question..
If he wanted to sell parts, he would have listed it in the parts section..
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
