driftaR32
i got brand new cefiro catbacks
450 free delivery in perth metro
or 450 + 80 postage anywhere else
http://www.4u.com.au/~dylan/products/a31cb.JPG
comes with gaskets, silencer to shut yuou car up for compliance etc etc
[email protected]
Hey just seeing if anyone has driftaR32's current email address? or contact details?
the email i found in this post quite awhile ago doesn't seem to exist anymore and i'm not sure he visits these forums much.
Also if anyone knows of anywhere else to get ceffy exhausts from that would be great. i know i can get a custom one made up but for 950 for a catback doesn't seem feasible when ppl like driftaR32 are/were selling them for 450.
Cheers
Ben
https://www.sau.com.au/forums/topic/84099-contact-details-for-driftar32/
