Nissan's Murano (spelling?) is now for sale in Aust. I think it is a great move and ever since my trip to Canada 2 months ago have been wondering why we miss out on cars like this and the Infinity series (G35 in particular).
I think they are one of the best looking 4wd's going around. Not sure about it's off road credentials or levels of equipment.
What are your thoughts?
Cheers
https://www.sau.com.au/forums/topic/84323-the-murano-in-aust/
I think the murano is going to replace my current 4.4 X5, I'm staggered by the level of built quality and equipements for the money!!!
hey hungry6
are you really willing to give up one of the best sounding v8's on the road? not sure about the 4.4l but the 4.8l sounds awesome.
maybe with a little exhaust work the 3.5 murano would sound good.
hey hungry6
Nar, I'm not going to miss the X5 trust me, As for the exhaust note, my Audi RS6 has got the best stock exhaust note in the business, bar non!!
are you having me on hungry6? you don't have a RS6? do you!!! do you really have a X5.
i love the way the flames shoot from the exhaust on my RS6, on the playstation anyway.
We have them at work(i work for nissan) and to breifly explain them, its basically vomit on wheels. with tacky plastic interior.
I work at the same complex as Nissan Sydney Homebush and the Murano was first seen here months ago.
It doesn't even get a 2nd glance given there are so many 4WDs in this complex.
It's not as bad as you make out but as far as this forum is concerned, it's another 4WD.
T.
It is basically a front-wheel-drive wagon — like the Maxima — but gets power delivered to the rear wheels when the front wheels lose traction.
Murano isn't one for the bush, just a front-drive wagon that seats five adults
And the base model is $51,990
Good for what it is i guess..
i dont get nissan... wtf is with the 350z style being copied to every model  :D
Maybe its coz the 350z actually sells?
I'm pretty sure Nissan know much more about marketing their cars than you do.
No I'm not having anyone on, I got a few different set of wheels, and the RS6 in one of my fav. daily driver.
My brother is also on this forum and he drive a red one, mine is a one of custom blue.
If you are that rich and can afford a x5 and rs6 u dont also own a gts-t or gtr do ya????
I'm not trying to brag or what ever, as I've said before, my passion for skylines have date back ages before these forums came up, I think I might be the first person here to own a r32 gtr, one of the original aussie delivered one, but since have own others, I also enjoy my r33 gtst that is powered by a RB26det, more so than the others, as it is the car, that has been taken furthest away from it original intent by the manufacturer.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
