Hi all,
I have a turbo for sale, I have been told it is a HKS T3G but Im not 100%. A/R on the compressor cover is .60. Cant seem to find the A/R of the exhaust. Supposedly supports around 350ps.
Numbers on the core are...
ZD 0139J
17200-114100
466261-1
This turbo has been rebuilt, it has never been used in AUS.
Turbo is internal wastegate but does NOT come with actuator. It is a plain bearing turbo.
Turbo also comes with a dump pipe.
Im asking $800 ONO
I am located in Sydney if you are interested my email is [email protected] or PM me.
Thanks
Edited by MYS013
https://www.sau.com.au/forums/topic/84639-turbo-for-sale/
