Hi people! ive just got my car back from its engine rebuild, and ive started the running in process. i need to find some roads with plenty of up-hills and corners. i know of a few, but i need to variate a bit because ill be covering a lot of ks. any suggestions?
thanks,
sam
https://www.sau.com.au/forums/topic/84675-good-roads/
I drove mine up and down the sea front from south up as far north as I could go.
Lots of low speed round abouts that see's nice loads when accelerating out.
Did you end up wiring open the wastegate so you can get some nice load in to it?
Its what I did and basically drove around flat foot N/A.
Not one little bit of blow back, zero oil in the intake pipes.
With the turbo connected you really can't get much load in to it without going overboard. :(
Edited by Cubes
https://www.sau.com.au/forums/topic/84675-good-roads/#findComment-1533919
hi Cubes! i was going to ask Shaun about wiring the wastegate open, but i forgot...
he said try to keep away from vacuum on the boost-guage, and to try and run it at 0 as much as possible. i found going up steep hills is good for this, also accelerating out of sweeping corners, & sometimes on straight roads i stop then start again. its a bit tricky, but im getting the hang of it :(
https://www.sau.com.au/forums/topic/84675-good-roads/#findComment-1533943
Wire it open your self? :P
You will need some s/steel wire and a little flat head screw driver to pull the circlip off.
That way you can simply hold it down. :(
Doesn't really go anywhere without boost but its easy to get a consistent load. Deceleration is also very bad. Drop it in neutral instead of using gears to slow down.
https://www.sau.com.au/forums/topic/84675-good-roads/#findComment-1533952
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
