As title says...
i want bonnet, guards even doors maybe..... id prefer white but if they are GTR items then i guess ill get them sprayed....
reply here or pm me with wat ya got
thanks
Ed
https://www.sau.com.au/forums/topic/84915-wanted-r32-front-panels/
im in sydney.....
ive got a stained bonnet and front guards and a bit on the door....
so im either looking for replacement white gts-t panels or
ill get some gtr ones and get them sprayed... not alot of point in buying gts-t panels and spraying them i may aswell get these ones done......
farken underground carparks!
Can get everything you need. Even GTR whole front end.
Send an email to me at [email protected] and i'll pass onto my mate at a jap wrecking yard. He has heaps of this gear in stock now.
Doors are around $125 each, boonet will be around $250 or so and panels around $100 each. (just a guess)
Cheers,
Greg Kruse - GK Technologies
www.gktech.com.au
