anyone had this drama
basically the turbo i have has a leak beteen the core and the exhaust housing
can it take it off and just buy a gasket remove the core and tighten it up or is this a job for a turbo specialist?
is it as simple as the above or could there be another drama
basically when its cold it leaks but after 10 minutes it all heats up and the leak disapears.
any sugestions
thanks in advance
pete
https://www.sau.com.au/forums/topic/84917-torbo-drama/
are you sure it's leaking at the core?
I had a similar problem a while back and I thought I had a boost leak, coz when the engine was cold I could hear this high pitched squeal as the turbo was spooling (not even making positive boost), but it disappeared when the engine warmed up.
The REAL problem showed itself after 2 hard sessions at darlington park at which time the exhaust manifold gasket(head > log manifold) shat itself. Obviously it had a minor leak for a while and the sustained hi revs etc saw the end of it.
Just a suggestion
Edited by Lazy-Bastard
https://www.sau.com.au/forums/topic/84917-torbo-drama/#findComment-1537735
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
