Hey all I have a standard R33 series 2 and I want to do it up but nothing crazy mostly for some performance and looks. I am planning three mods which I feel are enough for me but I want to make sure they are ok to do without having to get new fuel pump,injectors,ECU etc. I just want to bolt on 3 things and leave everything else stock and keep my car running good and not decrease the longevity of the engine. The mods I am planning on doing are as follows -
1. Full Turbo back exhaust with split dump and GTR Cat.
2. Hybrid Gt Spec FMIC kit
3. Panel air filter
I have been pming one of the members here and he has been great. I just want to see what the rest of the forum has to say. Also another thing I have been told the dreaded heatsoak can come into play when you install an aftermarket Exhaust and FMIC, is this true and would you recommend the application of heat wrap to the Exhaust and FMIC.
I think i covered everything I wanted to know. Any help would be great thanks.
https://www.sau.com.au/forums/topic/85069-issues-that-i-want-clarified/
I personally don't like the intercooler piping going back over in front of the engine above the fan but apart from that, what you have described is fine.
As for heat soak, I wouldn't worry about it for your desired level of performance.
yep, sounds about right for first round of mods, go for it :(
is very similar to what was done to my 33 first, should get you a decent gain and set you up for further additions in the future.
car may be a bit less fuel efficient but shouldn't alter reliability
Sweeet!!!!!!!!!!!!!!!!! Cant wait!! Oh yeh I was doing a little reading and in a hot 4 mag it was saying having a Large FMIC can cause overheating as the radiator is being denied cool air . Whats everyones opinion on that. As my last silly question at what stage do I need to look at Upgrading ECU,Pumps and all the other fun stuff???
I don't like the idea of chopping the fan blades as others have done to clear the intercooler piping. If this is an issue I suggest an electric thermo fan. They work great and don't get in the way.
If you keep the panel filter you can hook up your own cold air intake or do this. Pics below (hopefully). The air intake has been cut-away and some heavy plastic "welded" into place. Looks like it was always like that.
El Bee
3. Panel air filter
exhaust is good, fmic is good, air filter is good as youll keep the standard air box. you should now look into a piggyback system and a boost controller. run it at about 12psi and it should net you around 160-170rwkw which should be a nice and fairly quick streeter.
The piggyback apexi safc should set you back about $400 and $150 to fit and tune and $250 ish for an electronic boost controller. the biggest improvements come from the split dump / hiflow exhaust and the piggyback (if you get one). all in all looks good and should give some nice results fairly cheaply. Have you brought/paid for any of these parts yet?
sorry i missed
you don't need to upgrade the ecu but you will certainly benefit from the change. i can't recommend the apexi powerfc enough ($1500 fitted and tuned). the car will drive amazingly better once fitted and you get rid of all the stock limits. stock fuel pump should be ok as long as you dont go over 12psi ish. any more boost pressure will risk the turbo and could lean it out also if the pump can't keep up.
you may find the stock clutch will start to slip once you do these mods however (i did anyway).
-= piggyback vs replacement ecu =-
-= apexi safc =-
price 550
pro cheap, good bang per buck
cons only alters air/fuel, limited tuning
-= apexi powerfc =-
price 1500
pro full engine management, no stock ecu limits, fully tunable
cons expensive
most people just go straight to the powerfc given the cost of the apexi safc and tune and fiddling around you could just go that little bit more and get a much more driveable car. also comes with the standard hand controlller which kicks ass
if you have any questions on the powerfc have a read of:
http://members.dodo.com.au/paul/docs/power...powerfc-faq.htm
Edited by paulr33
No I havent Paid for any of this yet. Im still asking questions to make sure I dont shove it all on my car and then start having probs. Im alittle confused now. Your saying I should look at a piggyback system and boost controller. I was under the impression I wouldnt need a Piggyback system for A FMIC,Exhaust and panel filter or do I need one now???. This is why Im asking so I dont do the wrong thing. Im not intending to go for a full rebuild and make my car as fast as most of you guys. All I want is the exhaust for the sound and power,FMIC cause I love the look of it and power once again and a panel filter for that extra power and induction noise while still using the standard air box. Funny enough Im not interested in boosting the car because by having the exhaust system the turbo is more efficient and I get a couple more PSI anyways and that would be heaps for me so I dont want a boost controller. But do I need a piggyback like the S AFC or power FC for these 3 mods or is the factory ECU capable of dealing with this comfortably?? Ive been told the ECU can "self learn" and detect the new mods and manage them. Thank Again for your responses this is great.
You don't need anything extra. As a matter of fact you don't need anything for a nice quick street car.
Some modifications point to, or actually require, other modifications being done.
Your 3 mods will improve overall performance and the standard ECU will not be phased by them.
El Bee
El Bee
Does everyone agree with this??
yes, that would be the consensus
can't say enough about the Hybrid GT FMIC... I was very impressed by the build quality and price and gained a healthy 30rwkw without noticable overheating or lack of throttle response... a good choice for you I think... although if you want limited modification and have a bit of cash to spend you could opt for an ARC FMIC that hooks up to the standard piping = no cutting
Interesting concept, just an FMIC, panel filter and an exhaust. Not much of a power increase there, maybe 20 rwkw at best. The real power increase from a turbo car comes from increasing the boost. There is at least another 25rwkw available from increasing the boost to 10 psi.
I achieved a 30 rwkw increase from the Stagea RB25DET by tuning (DFA) and boost increase (IEBC) with zero mechanical mods. That's why mechanical mods and no tuning seems a strange choice to me.
Whatever floats your boat
:D cheers :)
Noticable overheating?? I thought the whole point of the FMIC was to decrease heat?? How can you get overheating when adding a FMIC????
Because the cooler restricts airflow to the radiator.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
