model number vrx 825op
heres pix
http://www.pbase.com/don91e/inbox
its the last 3
Modeled by my baby :P
ok it comes with,
Head unit,
6 dick stacker
tv tuner
2 x Antennas
features
remote controlled
detachable face,
alot more but i just couldn't be bothered listing it,
i want $1000.00 firm, but if you want to negotiate then i want $1200.00 ono
pm me
Any1 want a tv in there car ?? :D
DOnnie
https://www.sau.com.au/forums/topic/8507-fs-clarion-tv-hu/
Guest nismogtsx
Oh and how good is the TV reception... I mean if you change locations ie. move the car a few metres do you have to re-tune the tv... How far do you drive before the tuning gets really bad...
Also what does the antenna look like is it big and ugly... A pic of the ant would be good...
https://www.sau.com.au/forums/topic/8507-fs-clarion-tv-hu/#findComment-126531
nismogtsx : the 6 stacka does not play vcds unfortuantely
4 rca's , 6 if u include the one for video IN, so it does have a video in, u CAN hook up PS2 to it
it actually has Kenwood antennas, so there pretty damn good, shit all over the standard clarion ones, ehhehe, these were $110 new each, reception is excellent, i work in 12 story building, park on lvl 4 and still get excellent reception, but i gotta stop watching the tennis/cricket while driving home, hahah getting me too g'd up :)
Donnie
WTB: im selling TV only , that red 180 is just a pic,
https://www.sau.com.au/forums/topic/8507-fs-clarion-tv-hu/#findComment-126851
  • 4 weeks later...
interested in a TRADE with cash adjustment...i have a Panasonic CQ-DF701W. i give you $650 + my panasonic headunit
Top of the range Panasonic
Spec:
The Panasonic MXE CQ-DF701w CD receiver features the high-resolution 3-D Dot Matrix Display, with its 3-D animations and richly detailed setup screens. The CFL backlight means it's super-bright for no-sweat viewing, day or night. MOSFET50 power delivers performance you've never heard from a built-in amplifier, and Super High Definition Bass bumps up your low frequencies for a big sound. Hook your portable MP3, MD or tape player to your vehicle's sound system through the auxiliary inputs. Key Features: detachable, fold-down face Day and Night faceplate 3-D Dot Matrix display spectrum analyzer Alphatuner V Super High Definition Bass (with "Boom" and "Tight" settings) 3 sets of 5-volt preamp outputs 80/120 Hz low-pass filter on sub outputs MOSFET50 amp chip auxiliary input CD changer controls wireless remote clock 25 watts RMS/50 peak x 4 channels CD frequency response 20-20,000 Hz CD signal-to-noise ratio 96 dB FM sensitivity 11 dBf
Rrp. $1199
https://www.sau.com.au/forums/topic/8507-fs-clarion-tv-hu/#findComment-165384
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
