plex 15th
  • Replies 261
Guest KILLER-T
I was playing around with the timing last wednesday night at the plex i dont want to play around with too many things at once knowing my luck if i gave the timing a few more deg advance and then cranked the boost up my engine would blow up half way down the strip my G/F would kill me she is still going off at me over the last rebuild:argue:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/13/#findComment-138144
Originally posted by macka
what u laughin at.......?
13.4 @105 is hardly anywhere near 12.9 @113
hey ya fat bastard, your memory aint so good these days. I've pulled a 13.105 @ 108 mph, which puts me a whole 0.107 behind you..!!
if I farted during the run I'd beat your 12.98. be afraid fatboy.
https://www.sau.com.au/forums/topic/8519-plex-15th/page/13/#findComment-138202
Osc@r, I think Macka was having a go at me and rev, with our stock snails, we haven't yet put our snails on steroids, yet.
Macka, what was the best time you ran before you changed your turbo? I didn't think we would have been able to push so deep into the 13's with the stock turbo, but it looks like the 'plex is providing some good times.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/13/#findComment-138206
Sorry I thought you both had them, then Macka really should be doing much better than you?
17psi? What boost do you currently run it at, or is it hard to tell with your bleeder/spike valve?
When is your EBC getting here, can't wait to see you beat Macka, then he'll have to wind his boost up.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/13/#findComment-138730
I wasnt talking to you A-hole
stock turbo cars as Paul says..
Go back to your silvia club where u belong!
https://www.sau.com.au/forums/topic/8519-plex-15th/page/13/#findComment-138969
See'ya:burnout:
Hes gotta run 17psi to even come close!
Hey Paul u battin for the other team? haha
could take that a couple of ways..
https://www.sau.com.au/forums/topic/8519-plex-15th/page/13/#findComment-138994
Works, Good luck, let me know when your going down to the plex, I'll come to see if you improve your times.
Macka, I'm not batting for the other side, just promoting some friendly rivalry, you know I love you the most.
See'ya:burnout:
Thats ok then.....
https://www.sau.com.au/forums/topic/8519-plex-15th/page/13/#findComment-139039
I've had a play with the s-afc II and it seems pretty easy to tune. Without a dyno I have already tuned in some fat-ass power across the rev range, used up a bit of fuel tho'. Richen the bottom end and lean the top end and bingo! The mid range is a little tricky
I am quite amazed at the amount of sting the s-afc gets out of the stock motor.
I think I'll aim for another 0.4 sec improvement, without toluene, on the good ol' 205's and 10psi.
https://www.sau.com.au/forums/topic/8519-plex-15th/page/13/#findComment-139149
rev, let us know when the car will debut with the S-AFCII, I'm sure a 13 flat would be impressive on the stock turbo. How can you monitor the A/F ratio of you car for tuning? or do you adjust the fuel and see if you increase the power?
Good luck for the 0.4sec improvement.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8519-plex-15th/page/13/#findComment-139286
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
