  • Replies 43
Originally posted by KamikazeR33
im sure this topic already came up joe :D
I am sure it has but that is just plain wrong advertising...
Some people think they know everthing even without do research!
Man I would be pissed off if you buy that car and find out it's just plain old RWD! not 4WD as it said. wouldn't you?
cheers
Joe
https://www.sau.com.au/forums/topic/8534-r33-gts-t-4wd/#findComment-124493
The R33 GTS-t 4WD does exist, but I only know of one in WA, so I expect that they are a very rare factory production. Similarly to the R33's with the VSPEC diff and such these cars came out with a feature that was not in the normal production. I'm not sure if it was ever considered a factory option, or whether they just produced them to see what the effect was.
Anyway I can say with some authority that it does exit, although the likelyhood of seeing one is very low.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8534-r33-gts-t-4wd/#findComment-124705
GTS-t VSPEC. The model you are talking about with the vspec diff was released as a production model, just in very limited numbers. I did have the specs for it somewhere and it was a fair bit more expensive than the normal gtst too when new. Never ever heard/seen of a factory awd gtst tho.
https://www.sau.com.au/forums/topic/8534-r33-gts-t-4wd/#findComment-124799
Yeah I feel kind of lucky to pick one up, knew that they were limited.
I'm guessing that the car I saw might have been one of the in-house models from Nissan, they do make some to order for the big tuning houses aswell.
I'm not mistaken by what I saw, I was there with a Engineering who does certification of ADR's, and he had never seen one either. Possibly not a production model, but too stock to have been aftermarket job.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8534-r33-gts-t-4wd/#findComment-124808
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
