I have searched high and low......
But i cant find a copy of the pfc hand contoler instructions in English.....
Has anyone got them and can you post them here for everyone.....
My new D spec pfc only has a warranty card in the box and the how to install the pfc guide in English/Jap....
Anyone???
Apexi PowerFC
http://members.dodo.com.au/paul/manuals/Ap...nder_manual.pdf
RX7 Hand Controller Manual (English) - Outdated
Hand Controller manual however outdated and designed for RX7. Just ignore the rotary bits in it and should be OK.
Apexi PowerFC
http://members.dodo.com.au/paul/manuals/Ap...r_FC_manual.pdf
Integra Install Manual (English) - Outdated
Install Manual for PowerFC. Designed for Integra. Just ignore the 4cyc shit in it. Only English copy of Install Maunal.
Apexi PowerFC
http://members.dodo.com.au/paul/manuals/po...ese-updated.pdf
Hand Controller Manual (new model) - Japanese Only
Most recent PowerFC Manual. Japanse Only. Handy to look at AFM options and Sensor check page as they heaps different to RX7 sensor page
Apexi PowerFC
http://members.dodo.com.au/paul/manuals/po...control-kit.pdf
Hand Controller Manual + Boost Control Kit (new model) - Japanese Only
Most recent PowerFC Manual (with boost controller kit). Japanse Only.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
