Hey guys, i want a good decent jap intercooler to put onto my car. Now just wondering what my best option were, hks, trust, apexi, etc ...
Also would you recomend buying a kit. Or just the intercooler, and getting a bit of custom piping?
https://www.sau.com.au/forums/topic/85454-intercoolers/
yeah, im not really interested in getting a hybrid, esp a copy, sure they mite be cheap, but heard good things and bad things about both, I would rather buy a quality product and rest assure that it will most likely have no problems whats so ever. Also heard that those hybrids can then to make a whistle sound, i couldnt stand it if mine did that. And I want to put quality parts onto my r33.
If i wanted a good cheap option, i could get a cut down truck core, and make some end tanks myself at work. But meh, I actualy want a quality product :D
https://www.sau.com.au/forums/topic/85454-intercoolers/#findComment-1549197
i got a blitz intercooler kit, was a bit expensive $1200 but im very very happy with it.
its always freezing cold :).
it uses the stock pipes as well so the input put goes under the intercooler.
kinda looks like this..
||||||__
|______
as oposed to the normal ones which look like this
___||||||||___
i do prefer the look of the normal one, but it looks cool anyways :)
edit: pictures didnt quite work.. u no what i mean tho :D
Edited by justin911
https://www.sau.com.au/forums/topic/85454-intercoolers/#findComment-1549261
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
