I know its like trying to sell ice to eskimos, but i'l give it a shot at advertising my skyline here.
I am looking to go back to finish my law degree next year, so the skyline needs to go to pay for the uni bills.
Its a 1993 R33 Skyline Sedan, Garage Impul Special Edition -
number 67 of 100 made (little plate under the bonnet)
Engine/Driveline Mods:
RB25DET with HKS 2835 Pro Spec S, internal gate with HKS adjustable acutator.
Apexi Power FC with Boost Controller kit
Apexi Air Filter pod
Splitfire Coilpacks
Nismo 550cc injectors
Z32 Air flow meter
R33 GTR Fuel Pump
R33 GTR Front Mount intercooler
5 speed manual conversion with NPC Ceramic clutch and Nismo Style Heavy presure plate with Redline Oil in the Gearbox and Diff.
3 inch exhaust from turbo back, with high flow 3inch cat with Impul Stainless Exhaust
Nismo Shortshifter
Exterior
Impul R33r Body kit - each part has Garage Impul Logo on it
Interior
Apexi PFC hand Controller.
Impul Momo Steering wheal
Impul Recaro Seats
Apexi Boost Guage
Suspension/Brakes/Wheels
Impul RS 17 inch Wheels with Falken ZE512 (235,45,17 front, 255,40,17 rear)
Impul Shocks
Impul Springs - Lowered.
Impul Sway bars
Impul Strut strut bars
DBA 4000 rotors with Ultimate Pads
Servicing/Performance:
Tuned at Mercury Motorsport
230.9rwkw @ 1.05 bar - could get more, if you wanted to play around with the actuator
currently has 124 000 kms - Serviced every 5000kms with Mobil 1 - timing belt and water pump and other belts all replaced with nissan genuine parts. No Leaks, funny noises, runs perfectly and never missed a beat.
A fast car that handles amazingly well, very direct and firm and something you can carry the family around in. If your looking for something different, this is it.
Photos and carsales add here:
http://www.carsales.com.au/pls/carsales/...p;category_id=3
I have also attached a link to the list of cars they have produced.
http://www.impul.co.jp/products/complete-index.htm
PRICE DROP $17900 ono, trades or swaps considered.
pm me or email me at [email protected] or
call me on 0412 750 418
thanks
Matty
Edited by ImpulR33R
https://www.sau.com.au/forums/topic/85510-r33r-impul-sedan-modded/
  • 2 months later...
  • 2 months later...
  • 5 months later...
  • 2 months later...
  • 1 month later...
  • 4 weeks later...
If you can find someone who wants to buy my stock 2005 BA XR6 5 speed manual with 32,000ks on it, I'll buy this instantly. I've had my eye on this for about a year.
The XR6 is on carsales for $28,000 with 12 months rego and 2 alpine 12" subs in it :P .
  • 4 weeks later...
  • 3 weeks later...
  • 2 months later...
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
