hey guyz i just wanna open up this topic to get info on how to mod my r32, i'm to cars but i've always loved cars now i own my own turbo car (nissan skyline r32 gtst) so i wanna kkow eveything there is to knowo about this car and its eengine and what it can do thanx heaps guyz!
https://www.sau.com.au/forums/topic/85537-new-members-to-turbo-car-any-tips/
more boost does not equal more power. it does however mean more heat. so take that into consideration before just "more boost" theory from your mates :). if you can make the engine breath easier then its more efficient and can wind the turbo in quicker (aka reduce lag). a nice 3" split dump pipe and 3" hiflow cat and 3" exhaust will certainly help that. if it breathes more it will flow more and come on earlier.
The basic near std mods that are safe and shouldn't even require it to be thrown on a dyno..
FMIC, Exhaust, new larger fuel pump (bosch or gtr), bleeder, copper spark plugs .8mm gap (NGK BCPR6E).
Dial in 15psi, set ignition timing to 15degree's and it should run fine providing injectors are fine.
Edited by Cubes
15psi is fine on the rb20det.
RB25det I wouldn't go past 12psi.
My RB20DET turbo ran 1bar and towards the end 1.1bar for 100,000km's. (170,000km's total)
I've always believed heat is the killer of the ceramic turbine wheel, not
so much overspeeding as on the rb20det 15psi is not overspeeding.
Dial in 20psi and you may see overspeeding but to be honest, if its not tuned I'd lay bets the heat will get to it first, heat being generated by a lean detonating mixture. :D
Lean mixtures create high egt's, retarded ignition timing creates high egt's.
So.. Run it richer and dial in more ignition timing = cooler egt's. Better for the turbo.
Edited by Cubes
what do u guyz mean about psi, and where do i dial in a psi btw i have a r32 so yeah anything to do with it plz let me know cause its my first time driving a turbo and a rear with drive
also i dont have the money thats why i got a r32 :P cheap car i can spend the rest of my money on minor mods :)
so where do i get all these parts and what do each parts do for the car, any suggestions where i can get these parts cheap thanx
PSI is the boost it runs.
There's no point upping the boost unless you have an exhaust.
Running simply an exhaust with the std. intercooler I wouldn't run more than 12psi.
Replace the stock intercooler with a larger front mount item, you can then run slightly higher boost.
Before you do anything Do a bit of searching via the search button. :)
Learn what everything is and means.
Do a bit of googling also.
http://auto.howstuffworks.com/turbo.htm
http://auto.howstuffworks.com/question122.htm
http://auto.howstuffworks.com/engine.htm
http://auto.howstuffworks.com/horsepower.htm
Edited by Cubes
thanx guyz for the tips but just wanna ask another thing what do u guyz mean about when u talk about 1bar of boost, cause i thought that psi is boost then what is this bar thing can someone explain
I Don't know how much patience cubes has, but seriously man, u jus gotta start reading everything u can to find out about turbos n the rest. FAQ sections are very good. Its helpful to know how the engine works, how the turbo works, and how these components interact as a system.
howstuffworks is an awesome site, any one who doesn't think its worthwhile is ignorant.
I got an r32 gts-t coupe, it boosts 10 pounds (PSI) stock. When people say 0.8 bar or something like that, its a fraction of the 14.7 pounds mentioned before. 10 pounds in BAR would be just under 0.7 BAR (10/14.7)
The whole pound thing is that 1 BAR is what is atmospheric is. It is also what non-turbo cars drive around with. Your average non-turbo car mixes 14.7 parts of air to 1 part of fuel. Turbos force more air into the engine than the normal atmo engine, so if we boost 10PSI more thats around a 75% increase making our little 2lt much more powerful. Keep in mind, that the more boost, the more fuel is compensated by the car. Basically, the more air and fuel you can cram in your engine on 1 stroke, the better. As mentioned before, the cooler it is, the better.
You should find something like that on howstuffworks.com amongst many other useful informations.
Lastly, if you don't already have a turbo timer, get one or take it easy the last few minutes of your journey otherwise you will damage your turbs over time. Keep your car regularly serviced. If you got shit fuel economy (400km to a tank or less) change your oxygen sensor (search for a post on it). Cops love to pull skylines over: if you get pulled over, don't talk too much, and try and see if the cop is dopey with cars so you can trick him out of defecting you which leads me to this - try and keep your as obviously roadworthy as possible.
Edited by SuAvE-1
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
