Theres none of this..."drive it 3 times broooo then the motor needs a rebuild"... what the hell is that nonsense. If its properly set up and tuned then you wont have any problems.
This reputation of unreliability is more to do with the early rotaries, particularly those by manufacturer NSU and early (pre RX7) Mazda rotaries. Vehicles such as the 1960's NSU Ro80 were notoriously unreliable. The engine was guarenteed by the manufacturer, and NSU had to make countless engine rebuilds and replacements for free. 4 or 5 engine rebuilds were not uncommon. It got to the point where the manufacturer ended up broke and were swallowed by the Audi/VW group. Audi/VW ultimately killed off the development of the rotary engine in favour of the more conventional piston engine. The NSU design team went on to design the far less inspiring Audi 100. (Although in their defence they did drop a triple rotor into a limited number of 100's just for a bit of fun in the late 70's).
Imagine how insane it would have been if the Audi Quattro which took the Rally scene by storm in the early 80's with its turbocharged all wheel drive drivetrain also ran a rotary engine? It could have happened.
The reputation doesn't really apply to modern 13B and 20B rotaries. Mazda proved that when they became the first Japanese manufacturer to win the LeMans 24 hour race.
Anyone interested in classic rotaries may want to check out this article Rotary Engined Classics
  • Replies 40
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
