Gidday all,
I'm thinking about buying a lambia sensor and having a go (carefully) at tuning my car myself. ( have a friend who's tuned a few vl turbos etc) Just wondering if anyone can recommend any brands and know prices? I know my way around my pfc pretty well now - it can't be that hard - just time consuming but a great learning experience. Every time I get my car tuned it costs a good whack - and I'd like to check AFR's every now and again anyway.
I saw a thread sydneykid made ages ago about buying a lambia sensor and hiring it out for a week for a fee - did anything come of that?
Cheers
https://www.sau.com.au/forums/topic/85672-purchasing-a-lambia-sensor/
Its lamda :) Or more commonly known as a wideband o2 sensor.
I recommend innovate motorsports LM-1. I have one and its great. Only thing is that you have to buy it from overseas. Thing is IMO its kinda hard to isolate load points on the street for a novice tuner. Dyno is always best..
Edited by Busky2k
  • 3 weeks later...
or you could buy local from techedge
http://wbo2.com/default.htm
That's what I've done - got the 2E0 kit with bosch wide band oxygen sensor - it was the cheapest option.
I'll get it tuned professionally but it'll be a good thing to be able to check AFR's whenever I want.
Cheers
Hmm I've been quite keen to look into this, so roughly what are we looking at here for prices?
And do these sensors go into the factory O2 sensor port? I'm reading into it now but a quick short cut to the basics wouldn't be so bad? :P
If you read on the techedge website they say not to mount it too close to the turbo as they won't read right. The best place is before the cat - probably in the down pipe - that's where we'll mount it.
It wasn't as expensive as the ones from the states - all up under 400 AUD with the wide band O2 sensor although I'm not sure how good it'll be.
I use a Bosch LSM-11 sensor in conjunction with a Motec meter. The LSM-11 has been around awhile and is probably getting a bit old now in terms of the technology. Sensor itself was $500+ the last time I bought one, but that was quite awhile ago now.
http://apps.bosch.com.au/motorsport/downlo...oxygenlsm11.pdf
Wide band oxygen sensors have come down in price a lot.
http://wbo2.com/lsu/sensors.htm
I got the 0 258 007 057.
I see that motec use the 6066 which uses a bigger opening and is quicker to react but apparently can cause it to be sensitive to exhaust gas temperature fluctuations (probably most likely in a turbo application) because of this.
The 7057 was around 150AUD if I can remember correctly.
Cheers
nice info!!!
so has anyone got any concrete info on AFR's and what other people are using? like race teams etc etc?
No idea about race teams - a normal number from what I've seen is 14.7:1 for closed loop (apexi pfc) and under full load 11.9:1, although I've heard people say they lean out to 12.5:1? @ full load - guess it depends how safe you want your tune.
There's a good topic on tuning with a pfc in the stick forced induction quick reference guide at the top of this section.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
