Yeah mate got one in the beast at the moment, they do feel significantly down on power but since the fj20et dont boost till late and the fj20e has a fair surge of power once you get over 3500rpm it still makes things interesting, oh and dont forget the fj20e sounds sooooo much better at full tilt (i have a 3in straight through exhaust + extractors), and thats all i wanted anyhow.
https://www.sau.com.au/forums/topic/85735-na-fj/#findComment-1553044
Yeah, mine is an NA FJ as well. Genuine DR30 RS. I can't wait until Xmas, when I put the snail on the side. :ph34r: CAMS won't let me use anything other than the factory turbo, so if anyone has any hints on how to make good torque with the factory setup and a NA engine, I'm all ears.
Oh, and the sound is glorious! My car has no sound deadener, no interior, no parcel shelf, no rear seats - nothing. It is just one big echo chamber for that exhaust note. With a helmet on, it is bliss. Without a helmet on, your ears bleed.
I have never driven a DR with a turbo, so I have nothing to compare it to. Can't wait though...
Edited by Matty T
https://www.sau.com.au/forums/topic/85735-na-fj/#findComment-1554257
Yeah, I was figuring it would HAVE to sound better... FJ20ET's sound even worse than SR20's :D
So a 3 inch works ok?  Maybe I wont have to change to my pissy exhaust after all.....
I'll pretend you didn't even say that Adam...SR's and FJ's are to completly different sounds, an FJ sounds more L series...You have fun with your NA whilst we keep boosting around :D
https://www.sau.com.au/forums/topic/85735-na-fj/#findComment-1555103
My FJ was even more trucklike than an SR according to my friends... They may have been bullshitting me as I never heard it from outside, but thats how they described it
NA will be fun, and noisey :P
Fair rekon your friends need their hearing checked hey....
Ever thought of turboing the NA motor?????
https://www.sau.com.au/forums/topic/85735-na-fj/#findComment-1557728
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
