I'm about to fit an bosch fuelpump and I'd like to know how the factory system works before I try to improve or bypass it.
What components are involved in it's operation and where are they located? ECU pinouts? TPS? resistor, relays etc
A circuit diagram or a link to a manual that covers it would be great.
https://www.sau.com.au/forums/topic/86251-r32-fuelpump-speed-controller/
Based on the wiring diagrams and the service manual (ie i've never actually pulled one apart) all the stock system appears to do is switch a resistor inline with the pump, thereby dropping the pump voltage. This is controlled by a signal wire from the ECU.
Not sure exactly what the ECU uses to determine when it should be at "low", possibly neutral switch or idle switch or both?
I can look up more when I get home.
Thanks champ, some more details would be great.
Is your service manual a book or CD?
B0oStEr,
Assuming you have an R32 GTST the ecu activates the Fuel Pump Control Modulator (FPCM) when the engine is cold. In essence the FPCM is just a switch which is earthed when the engine is cold. The FPCM is wired in parallel with the resister pack located in the engine bay on the left strut tower (adjacent to the turbo).
Basically it reduces the resistance downstream of the fuel pump when cold allowing a greater current flow and hence pressure for cold conditions (acts like cold enrichment). Once warm the FPCM circuit is open resulting in reduced current flow and hence fuel pressure.
According to the wiring diagram the non-turbo R32's don't have an FPCM but also don't have the additional resistor in line with the fuel pump. The fuel pump resistor is about 0.8 ohms.
If you disconnect the fuel pump resister (in the engine bay) and start the car when cold it should run fine whilst the FPCM is activated. Once the FPCM is switched off (when warm) the car will stall because the parallel circuit with the fuel pump resistor is also open circuited.
Please note the above applies at idle but haven't tested above idle. The GTRs operate differently again.
The above applies to R33 GTSTs but the location of the resister pack and possibly the FPCM is different. Again not sure what happens above idle.
Hope this helps.
Edited by BH_SLO32
Its also interestering to note that when you fit the PFC up it no longer uses the high/low.
Its always on high.
Still have two stage fuel pump voltage on mine with a powerFC, can hear the pump speed up when you open the throttle.
PlasticSan,
Your PowerFC is a R32 AP Engineering?
I 100% no longer have the 2 stage highlow. For example when idling then touch the accelerator.
I can always hear the fuel pump on high, plug the stock ecu back in and I've got the 2 stage back. :)
Strange.
EDIT: I've just had a quick look to try and track down what car you drive. It appears to be an R33, so.. Not an R32. :D
Edited by Cubes
B0oStEr,
......Basically it reduces the resistance downstream of the fuel pump when cold allowing a greater current flow and hence pressure for cold conditions (acts like cold enrichment). Once warm the FPCM circuit is open resulting in reduced current flow and hence fuel pressure.
I was under the impression the fuel pressure reg. controls fuel pressure. By increasing/decreasing the voltage across the pump, the FLOW capacity of the pump would increased/decreased. I'm not sure why it would be increased at idle because the coolant temp sensor combined with the ecu would increase the injector pulse width. Obviously the pump will speed up under load to increase the fuel available to the injectors
It's my understanding that the fuelpump speed control switches the pumps earth from direct to the chassis to earth through the resistor so that it reduces pump speed and noise when full capacity isn't required eg at idle and possibly at cruise.
If the pfc in the r32 doesn't operate the speed control then the decision to ditch it has been made for me.
All I need to know is how to wire my 040.
Should I run a new earth from pump directly to the chassis?
Should I upgrade the power wire by using a relay and running a new wire from the battery?
where did you guys get the servie manual for a r32 GTST from? i have been looking for one for ages
You can buy them online from the guys who translated them: http://www.jpnz.co.nz
I think there are some aussie distributors as well.
The way its drawn in the diagrams is that the negative terminal of the puel pump is connected to two places - the dropping resistor and the FPCM. The resistor is hardwired between the pumps negative terminal and the earth. The FPCM switches on and off based on the ECU signal and effectively shorts out the dropping resistor.
Don't know why Nissan did it this way. I guess if the FPCM fails, then you can still run the pump at low speed so you can limp somewhere to get it fixed.
The easiest way to get around the whole low/high speed issue with a big bosch pump is to run dedicated 20amp wire from the battery to the new pump and use the existing wire as a trigger for a new relay. Then run a new earth wire to the chassis (or back to the battery if you are paranoid about voltage drop).
That way, whether the ecu is outputting high or low speed, the relay is still closed so the pump is getting a constant high voltage (which the bosch pumps need anyway)
Yes, the fuel pressure regulator controls the pressure in the fuel rail relative to the manifold pressure (most factory regulators are set to maintain the fuel rail pressure at about 43kPa above the manifold pressure). Increasing the speed of the fuel pump (by increasing the current draw) increases the pressure and flow of the pump. An increase in flow is only achievable by increasing the pressure because of an increase in pipe friction and fitting losses. The friction loss increases at the rate of the square of the line velocity.
Using a large capacity pump like the Bosch O44 will naturally increase the base fuel rail pressure ( >43kPa say) if the same voltage is applied to the pump. Increasing the voltage will result in an increase in the pump speed and hence pressure and flow.
When upgrading a pump you need to consider its flow capacity at a given pressure and voltage. If the standard voltage available at the pump is deemed to be inadequate the best approach is to install a dedicated power feed to the pump to minimise voltage drop. You can then install a relay and trigger it off the old fuel pump power supply as suggested by BHDAVE.
Hope this explains things.
Edited by BH_SLO32
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
