this engine is a V12 jaguar block fitted with 6CYL 24 valve twin cam head which have been converted to belt drive!Note one head had to be fitted on backwards so to have both the inlets in the centre of the engine...vast amount of work is unseen...with the cams extended,valve covers shortened..this motor is fitted in a mid mount configuration of an e type jag...The e types are very ugly..not this one!It has 11/2 feet removed from the front of the vehicle and placed at the rear...it has an RX7 series 6 hatch on the back and looking through the rear hatch screen you see the valve covers....and 12 fkn big trumpets!!!!Its wiked...F1 style front suspesion i will post some pics soon
Guest nismogtsx
We want more pics......
YEAH thats a good idea nismogtsx... YEAH
I think he is rather tallanted (i think thats how to speel it)
I wish i had the time to do that sort of stuff... You see i have a very short attention span... If it aint finished in 5 monutes id better go and have another beer.... Then when i come back to it i dont remember what i was gonna do and it ends up in the corner...
It will most likely be an I.C.V..Individuly construted vehicle...Although this guy is a M.I.A.M.E so he can do anything as long as he uses his noggin and he can get away with it.In my experience..most of the guys that issue engineer's reports dont have a fkn clue about making stuff there knowledge is all theory.
  • 5 months later...
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
