hey.. i'm new
Guest J.Spec00
Originally posted by INASNT
is that a mates car u are gonna buy?
u recon it will still be around when u get on your p's?
its not a mates car..
its from a private importer..
obviously when i get around to getting a car... it wont be around.. but i hope to get something similar...
so ambz... ur GO SPEED RACER is a calibra... *cough* *cough*
lol.. only J/K
https://www.sau.com.au/forums/topic/8678-hey-im-new/#findComment-127596
since the clothes u supplied me from your private collection had pee stained undies and all this hair on the bra's!!!
jesus christ? what the hell is going on????
1.) why were you looking to wear girls clothes?, ive heard rumours going around about this kinda thing, now they are confirmed
2.) why were they pee stained and hairy?
when u were cryiong in the test lab
https://www.sau.com.au/forums/topic/8678-hey-im-new/#findComment-127635
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
