what up mah peeps
Hey listen I bought a secondhand exhaust from Hikari and it needs a bit of a clean up before i take it to get the dump pipe made.
It is mild steel and there are some bits that have surface rust. (the flanges)
Now i wanted to scrub em off with a wire brush and then spray all the piping in that high temp black spraypaint so it all looks nice and then polish the twin mufflers.
But i also want to like flush the exhaust through.
and now the question...
DO you think that i could use carby cleaner or something similar to get some gunk out of it. like carbon caked on the inside.
I am not sure what to use or do, i dont think there is any problem with bolting it on but while it is sitting there doing nothing i might as well do something.
it is a jasma exhaust with a high flow cat, but the cat is dented, dunno if it will affect anything. hopefully not. i am considering knocking the cat out...(but i wouldnt cos its illegal) as an experiment if i choose not to use the cat. Do you think hypothetically that it will let alot of black smoke through the exhaust or will it just smell really bad with the extra gasses. would anyone have any hypothetical theories on this.
lata
RiaZ
https://www.sau.com.au/forums/topic/8702-exhaust-help/
I can't see too many problems with cleaning the exhaust, the only thing I would be careful of is the cat. I'm not sure what effect the cleaning agents would have on it, but probably not good.
In general the exhaust will get a bit caked from the unburnt fuel that passes through it, so any type of engine style cleaner should work.
How bad is the dent, if it causes the exhaust gases to swirl then you could potentially loose a bit of power, but probably not worth worrying about.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8702-exhaust-help/#findComment-127540
the cat is oval shaped and the dent is on the join near where the piping goes into the cat. it doesnt seem to bad and it will be under the car so i am not ecpecting too many problems. still deciding what to do with the pipework, cos the cat seems old and I am thinking putting it in might be pointless as it could be too old to be of any use so i might just get a new high flow cat and use that instead.
Just need to find a small exhaust shop with patience. someone cheap as you would expect.
anyways i will let you know how the cleaning goes.
RiaZ
https://www.sau.com.au/forums/topic/8702-exhaust-help/#findComment-128384
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
