*price alteration*
Item: 1998 R33 GTSt
Item Condition: Excellent
Rebuilt Engine by Amberley Autos (around 30,000km old, Receipts, Service Records and Dyno charts)
Custom forged pistons
Shot peened and lengthened conrods
Crack tested, strengthened and linished crank
1.2mm metal headgasket
550cc SARD injectors
Bosch internal fuel pump
DNA Motor sport front mount intercooler
Trust air filter
K5-660PS Blitz turbo
Custom stainless steel exhaust manifold
53mm Blitz external waste gate
Custom stainless steel turbine outlet into a highflowed catconverter into a 89mm Fujitsubo Legalis SuperR exhaust
PowerFC w/handcontroler
Defi BF Oil temp and Boost gauges
Some minor stereo improvements, nothing fancy
GTR copy front bar and skirts
HKS HypermaxII adjustable coilovers
Whiteline Rear and Front antiswaybar
Whiteline Front adjustable towerbrace
Factory rear adjustable towerbrace
New Daikin super heavy full faced button clutch
KAAZ 2way SuperLSD
Tomei HICAS lock
18x8 Enkei Bortex wheels
Mongoose Alarm
The Blitz K5 turbo kit has been on the car only since the 2nd of September 2005
Completely reliable, starts everytime and runs perfectly.
Maintained by Amberley Autos, always garaged.
Rego till November 2006
Contact Details: 0414 805 480 James
Reason for Selling: Need a normal car, spent too much on this one
Price: $27,000 Negotiable
Contact Details: 0414 805 480 James ([email protected])
If you want it to see more power, than a set of cams, bigger injectors and an extra fuel pump will see you happy.
This is a complete package car. You won’t need to do much more as you’ll be happy with the way it is.
ps: dont mind the drift nationals sticker on the windscreen...its only there to promo Fulllock. I cant do that crab crawling sh|t and i dont act like i do with the car either.
SOLD
Edited by whistla
https://www.sau.com.au/forums/topic/87034-1998-s2-r33-gtst-forsale/
Ive seen the car before and Its gotta be one of the hottest R33 GTS-Ts ive seen around! The mod list looks insane as well, good value for 30K!
Good luck with the sale.
Free BUMP for my brother whistlazzz
I have seen this car come from a mild street car to a full blown weapon.
Its the perfect car to buy because there is no more to spend on it - its complete !
Tuned professionally giving a nice linear torque curve makes the seemingly large turbo spool as if it was no bigger than a t3/t4. The useable power is fcking awesome.
I'd Buy it, but i am afraid of what i might do to it =\
  • 3 weeks later...
How many rwkw does it have?
Sorry for the delay.
Its currently got 276rwKw on a very sedate tune/setting. It is more than capable of doing alot more.
Im just a girl as some would say, and didnt want much more for street use.
the K5 is a 660PS rated turbo.
Same turbo on two other RB25DETs has seen it produce +400rwKw, but ofcourse with the supporting modifications.
eg: alot bigger injectors/pumps and cams
Edited by whistla
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
