*price alteration*
Item: 1998 R33 GTSt
Item Condition: Excellent
Rebuilt Engine by Amberley Autos (around 30,000km old, Receipts, Service Records and Dyno charts)
Custom forged pistons
Shot peened and lengthened conrods
Crack tested, strengthened and linished crank
1.2mm metal headgasket
550cc SARD injectors
Bosch internal fuel pump
DNA Motor sport front mount intercooler
Trust air filter
K5-660PS Blitz turbo
Custom stainless steel exhaust manifold
53mm Blitz external waste gate
Custom stainless steel turbine outlet into a highflowed catconverter into a 89mm Fujitsubo Legalis SuperR exhaust
PowerFC w/handcontroler
Defi BF Oil temp and Boost gauges
Some minor stereo improvements, nothing fancy
GTR copy front bar and skirts
HKS HypermaxII adjustable coilovers
Whiteline Rear and Front antiswaybar
Whiteline Front adjustable towerbrace
Factory rear adjustable towerbrace
New Daikin super heavy full faced button clutch
KAAZ 2way SuperLSD
Tomei HICAS lock
18x8 Enkei Bortex wheels
Mongoose Alarm
The Blitz K5 turbo kit has been on the car only since the 2nd of September 2005
Completely reliable, starts everytime and runs perfectly.
Maintained by Amberley Autos, always garaged.
Rego till November 2006
Contact Details: 0414 805 480 James
Reason for Selling: Need a normal car, spent too much on this one
Price: $27,000 Negotiable
Contact Details: 0414 805 480 James ([email protected])
If you want it to see more power, than a set of cams, bigger injectors and an extra fuel pump will see you happy.
This is a complete package car. You won’t need to do much more as you’ll be happy with the way it is.
ps: dont mind the drift nationals sticker on the windscreen...its only there to promo Fulllock. I cant do that crab crawling sh|t and i dont act like i do with the car either.
SOLD
Edited by whistla
https://www.sau.com.au/forums/topic/87034-1998-s2-r33-gtst-forsale/
Ive seen the car before and Its gotta be one of the hottest R33 GTS-Ts ive seen around! The mod list looks insane as well, good value for 30K!
Good luck with the sale.
Free BUMP for my brother whistlazzz
I have seen this car come from a mild street car to a full blown weapon.
Its the perfect car to buy because there is no more to spend on it - its complete !
Tuned professionally giving a nice linear torque curve makes the seemingly large turbo spool as if it was no bigger than a t3/t4. The useable power is fcking awesome.
I'd Buy it, but i am afraid of what i might do to it =\
  • 3 weeks later...
How many rwkw does it have?
Sorry for the delay.
Its currently got 276rwKw on a very sedate tune/setting. It is more than capable of doing alot more.
Im just a girl as some would say, and didnt want much more for street use.
the K5 is a 660PS rated turbo.
Same turbo on two other RB25DETs has seen it produce +400rwKw, but ofcourse with the supporting modifications.
eg: alot bigger injectors/pumps and cams
Edited by whistla
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
