Ok before anyone asks, no I haven't banged my engine! (touch wood!) I have just been following the arias piston thread and thought that these seem to get the nod on some occations...
so I gather they are made in the USA, what are the prices here like?
87mm seems the go also what about 9 : 1 or 8.5 : 1 ?
I have found some in the states for $970 aussie... complete with rings etc....
ideas :P
Contact Markr34gtr is the man to talk to for CP pistons (very nice product) i used a set from mark on a r34 gtr vspec making 500rwhp plus happily. They run a 0.0035 clearance which is pretty good for forged pistons.
pete
Williams, that's pretty cheap if they are complete with rings.
One thing you need to be careful of with CP pistons, is that you get different rings depending on where you buy the pistons from. CP don't make their own rings.
I know if you order from CP direct, you get a japanese made ring. If you buy a set here, I'm pretty sure you get a US made hastings ring.
Also, the 87mm pistons you buy here are not an off the shelf CP piston, they are a custom piston and use a different ring width to the 86.5mm pistons (and the US 87mm pistons)
By the way Tomei pistons run 0.002" to 0.00225" clearance.
ok the reason I ask is I have found a place in the USA that does RB26 CP pistons... 86.5 and 87mm same as what cousin blitz has got....
I found the price to be rather reasonable, and that is with American rings matched to the pistons....
oh and that price would be me picking them up in LA :huh: but that isnt an issue....
but I am (touch wood a lot!!) not looking at doing this for a while, just curious as to the price diff locally...
ok the second part of my question has been skipped, comp ratio??
pluses and minuses for 8.5 or 9
cheers!
oh and that price would be me picking them up in LA :( but that isnt an issue....
cheers!
Hey Ben, I think you'll find the American 87mm pistons will be a different piston to Nicks ones. The Aussie distributor custom orders the 87mm pistons with thinner rings.
G'day Mik,
I can't say either way regarding the thinner rings, just that the CP pistons are for the RB26 and come in the 4 different options of size and comp....
I have emailed them regarding the rings spec...
Rob82...
no my engine is still in 1 piece... I was just asking out of curiosity....
I should think my engine should be going for sometime yet!!!!
here is the link to the site....
http://www.bnecustoms.com/store/home.php?cat=453
and CP
http://www.cppistons.com/sCompactNEW.htm
ben,
why aren't u speaking to jim @ dart? he recommends arias because of the ring quality (eqiuvalent of nismo rings)
at the end of the day its like asking the question of holden & ford?
it is personal opinion & they both have 4 wheels...
marko
hey mate :(
yeah I had the discussion about either of them a while back, I was just curious about the CP as I don't know much about them, and I know the arias are a good thing....
so how many km to go till u get some real boost? :)
hey mate ;)
so how many km to go till u get some real boost? ;)
Ben,
CRD recommends 1500km whereas Dart recommends 1000km
i may do 1250km :)
I hear you may be moving to Adelaide for good!?
Marko
yep! leaving old Sydney town...
well never say never.... but Adelaide is home, and plenty of GT-R friendly roads over there...
I'll just commute for work ;)
you will need some semi's for that car of yours now surely!!!
ok this back in from the piston supplier....
"The rings are produced by CP Pistons. They are made of tool steel. Tool steel
is harder and stronger than the chromoly ones that everyone else sells. Plus
the tool steel rings seat a lot faster than the chromoly ones.
You also get Chromoly 5100 series pins, and wire lock retainers."
so they are made my CP?
That is very odd. I was told CP don't make rings. The guys at CP in the states told me that they supply a Jap made ring.
The aussie dist supplies either total seal or hastings (US made rings)
Another weird thing...I always thought chromoly (ie chrome molybdeum (spelling??)) WAS tool steel!! ;)
But in any case, if I were to use CP rings, I would get them custom made to accept OEM rings and OEM tru arc locks.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
