Had a look at the SEVS lsit today (I think it's the current one, not sure if it will change as of May 8th) and it looks as though pretty much ALL R-34's will be eligible to import.
That includes the RB25DE atmo and even the RB20DE...
The link is here.
Just click on the second-last option on the left of the page: "Register of Specialist and Enthusiast Vehicles"
Also, if you have time, check out the link above that ("SEVS Information" - the third-last option) and go through the bulletins towards the bottom of that page. Lots of reading, but an insight into what they're trying to do.
Either way, it sucks in my opinion. Why restrict the number of cars coming into the country, when they serve the purpose of:
- satisfying a market not already catered to;
- supporting a lot of new or fairly-recently established businesses;
- protecting the jobs of the people employed in these businesses; etc.
They state in the first bulletin that the purpose is to ensure that quality cars are coming into the country, which is fair enough if that was their only agenda.
I'm sure I'm not the only one who thinks that it's more of a money-making scheme and/or a pandering to the requests of the bigger local car-makers. I think that's including Toyota, Nissan and Mitsubishi - who were obviously not game enough to cater to the market in the first place, and are now jealous that they've missed their opportunity and/or are losing sales to the "Grey Import" dealers and importers. I've also heard that parties responsible for implementing the SEVS rulings have actually clearly stated that they are deliberately out to reduce or shut down the industry bracket...
Oh well, time will tell.
I'm going to go through all the bulletins and see where it seems to be leading us.
Originally posted by blukie
I'm interested in purchasing a R34 4 door
Here is a pretty cheap one Blukie, in tiptronic form.
For sale: RARE 1998 R34 GT-T Turbo, 4-DOOR, Silver, Auto, $23,900 plus tyres and ORC's. This is available via Prestige Motorsport in Perth [hope you dont mind Geoff!]
Contact:
Geoff Risbey
Manager
Prestige Motorsport
0418 944 253
www.prestigemotorsport.com.au
At your service Mon to Sat from 9am to 6pm WST
Thankyou all for your replies. NISMO R34 thanks for the example you spotted. I have spoken to Geoff breifly about this car and yes it will be $7000.00 to comply this car.
Does anyone know why ????
1 reason I got from Geoff was that the front headlights have to be replaced because the projector headlamps do not comply. So basically if you purchase an R34, I believe that you pay someone to downgrade your headlamps, you pay labour, pay for the down graded headlamps and they don't even give U back the originals.
You purchase the car, I believe you have the right the keep what comes with it.
I really, really want an R34 4 door, but can't justify paying someone to "downgrade the car" . That's stupidity.
Well it looks like it's back to HSV for me.
SEVS rules SUCK.
The 2 door is generally the same in regards to the lights - if you are lucky you may get to keep the originals :P
SEVS rules SUCK.
it cause therew is only two dudes in australia who can do it for you
one in sydney
and one of these people are the only people in aust that do the headlight conversions leaglly.
if you need one done give us a bell cause i can hook you up for a cheaper price
pete
0409226626
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
