I need to raise my car by 5-10cm. The front bar is too low. I was keen to do it my self, as I have height adjustable coil overs, but I dont have any C spanners (I don't like using a hammer and a screw driver).
I was going to get a shop to do it, to adjust the ride height it would take them about an hour@ $69/hour.
I was then told this would only effect the looks (and save the front bar). to retain or improve the handling the supsension would need to be balanced using weights , which would take about 3 hours @ $69/hour.
Question:
Has anyone else had their suspension tunned and was it worth it?
https://www.sau.com.au/forums/topic/8754-suspension-tunning-vs-ride-height/
Lifting the car by 3" will NOT change how much weight is at each corner ???? Sounds like someone is trying to rip you. I did my own suspension tune using some industrial scales at the local transport shop and found that the car sat really weird as one side is higher than the other and it didn't feel any different to before so I just put it back to normal. Just make sure it sits the same height on both sides with a touch more height in the rear.
if you go the corner weight thing make sure that they do it with you in the car so when your on the track the car sits perfetly flat
i love people that fully"sic" adjustable suspension and lower it all the way thus making the handeling shithouse.
got it done properly and it will handel a treat.
if you go too low you get the standard nissan drift setting eg no grip at the rear
pete
Thanks guys
I am not sure if anyone actually tuned the suspension before, its likely the car was just dumped..... so even though it might only be raised slightly (1"-3") at least I would know it was done properly ... I am pretty sure it hits the bump stops every so often
losing the negative rear camber drift set up will be great for the track and wet weather ...... still love the sideways motion though ... so hopefully there could be a compromise or maybe a need for more power .....
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
