most likely not...i believe all electronic boost controllers are in metric form...it would be .6 bar of pressure in kg/cm.
i think .6 would be like 8-9 psi?? Is that a correct anyone?
took my car for a run tonight after finding a hidden boost controller just got the car a couple of weeks ago dont really know the mods on it because it was import from japan. but i put it on .850 and pushed it not sure if it was safe... what is it meant to be on with stock setting
I personally wouldn't run it any higher than that (.85 BAR- 13.5PSI).
Because if it is stock the intercooler can't cool the air efficiently and you may get fuel lean out issues, detonation (engine damage)
At night time you could get away with that boost.
You should try and see what sort orf mods have been done to your car.
Guessing stock boost would be .6BAR 8-9PSI?
