Group Personal Training - Northern Beaches
Hi All,
Don't know if this is allowed or not - but I wanted to give Vicki a plug in here as she has just started a new business.
Vicki has helped me loose over 10kgs of weight over the last 4-5 months.
If you are interested in excellent training at affordable prices - This is the place to go:
Cheers,
B-Man.
PS - here's the plug:
INTRODUCING STEP INTO LIFE
As some of you may know I have just purchased a Step into Life group personal training franchise at Manly. Classes have begun & I thought you may be interested in knowing exactly what is happening.
Step into Life is Australia’s leading fitness program. We are unique in that we are experts at the exercise component of weight loss, fat loss and fitness improvement. Step into Life has perfected group exercise programs that allow individuals of all ages, sizes & fitness levels to exercise in a FUN group environment. Each person is on an individualised program within the group ensuring that everyone meets their goals & gets a suitable workout each & every session.
I am a qualified Personal Trainer and fully trained in the Step into Life program. I offer a flexible timetable with a variety of classes (currently including cardiovascular, toning & boxing) being held each week, at Hinkler Park in Manly. I am able to design a program that suits your budget, your goals and your schedule.
Step into Life offers all new participants the opportunity to try the Step into Life program with no further obligation, with an Introductory Free Trial offer & I would like to extend this offer to yourself & all of your friends. Please feel free to forward this e-mail onto all your contacts so that everyone can take up this free offer.
Don’t worry if you do not live near Manly, Step into Life is a national based company with 10 franchises within NSW alone, including new franchises now open at Penrith & Chipping Norton.
For more details about Step into Life, or if you would like to book in for a free introductory class please call me on 9976.6175 or 0408.013.862.
I look forward to hearing from you soon.
Yours faithfully
Vicki Tillott
Step into Life Manly
manlysil(at)bigpond(dot)net(dot)au
Boo Manly.
I do need a personal trainer though ... *pokes flab*
HA HA HA i know the feeling.
Now im not training full time anymore i can't believe the difference it makes :P
It sounds like Vicki has a good set up and knows what she's doing.
Goodluck to her and the business and anyone that decides on getting fit and taking a hold of life ;)
Cheers B
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
