look out for the silvia
i have owned both cars, currently own a S15
all i have done is full exhaust
last weekend, took on my mates R33 GTST
he was running 15psi FMIC full exhaust airfilter and a chip
on paper i know his would win, but worth some fun
we lined them up and i matched him all the way, twice!
at no stage he was pulling away over the 400m
each car can be worked to out-perform the other, there are many 10sec 200SXs out there, like the many R33s etc running in the 10s
if u want to always win, go but a 13b turbo rotary and put it in a small car and enjoy killing everything (but you wont enjoy the reliability)
  • Replies 47
Originally posted by kabab
You let me in once in traffic (back before you where on these forums) i remember you car quiet well !!
Cheers man !!
im only vishes when im racing...otherwise i drive like ur average volvo driver ;)
well next time say hi :D
most ppl beep at me and im like 'wtf am i doing wrong!!!' when they're only saying hi ;)
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
