  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeh fair enuff as long as it is kept in here i suppose its ok but still keep away from the double posting habit.
Oh and if u want mindless drivel y not post ure msn address? then u can talk all u want in private.
And what about Skyzerr, 5600 legitimate posts, I don't think so. 20 posts per day. And he's a moderator, so I can't see why it is ok for some and not others, I have not posted too much crap in the legitimate threads anymore.
See'ya:burnout:
Skyzer has been around since the birth of SAU and he does alot of his whoring in the wasteland. Otherwise he keeps it on track. At the rate ure going vspec u will have overtaken him in 2 months (plus he gets 2 posts for every actual post)(rumored)
Yeah, I'm not knocking Skyzerr, he can do what he want's, but seeing as I'm posting in the WA wasteland then whats the big deal. It's not like you need to moderate the Whoreland.
And since it has been created I haven't started any whoring in other threads, just joined in.
See'ya:burnout:
No big deal, its just that all the double posting should be seen in the same light a ricing and nothing more. Its not good for any1 but the person doin it.
Oh yeh, the new SWs just blow, admitted the 2nd was heaps better than the first but IMHO George Lucas is just after a retirement plan :( (GL aka punk ass sellout muther *****r)
Originally posted by GTS-t VSPEC
I disagree, I think that the original SW's was good for it's time, but people are nastalgic and don't want to like the new ones. The new SW are better all round, but can't wait till the originals are released on DVD.
See'ya:burnout:
Agreed!
Yep LOTR does kik some ass, thought it would have been better though if they broke it into 5 movies.
the first was good because nothing happens in the first 2 books apart from running around and finding food and sleeping and walking so it fit the movie well and was as full as it could be but the 2nd was too rushed and the plot could not be explained properly and with enuff depth. they needed more time, especially at helms deep.
I think reading the book spoiled it for me
IRC is for loosers.
LOTR's has been done aswell as the movies allows, there is no-way that they would be allowed to split it into 5 movies, and yes there are some areas only touched on and some area's deserve more time but they have to restrict it. I think they did a very good job, and the third movie should rock, lots of action.
See'ya:burnout:
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
