  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i am at tafe!
bully boost controllers control boost
so u can up them levels lol JOKING (i know u know that)
profec b spec i heard is quite good
so is Blitz Dual SBC SPec S
or u can go the brand new Profec E-01 with little monitor screen
adrian ;)
Well, you can get them starting from $350 all the way up to over $1000. I have a Blitz SBC Spec S, about $700, I'm very happy with it.
Osc@r just bought one quite cheap but it's not holding boost too well. So the more money you spend then often the better the controller. The minimum you'll need is $450 for one of the cheaper ones.
You could always try a 2nd hand one.
See'ya:burnout:
Amazing , phptf giving out sensible advice AGAIN , especially on a whoring thread.
Bully , I got a profec thingo out the back that came off something I bought ages ago.
Appears complete ( I think ) but dunno what it's worth.
can find out more if interested.
Cheers
Ken
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
