Originally posted by Nizmo
ken after ya finished with the missus dishes come over and do mine will ya :P !!
Most guys do the polite thing by me. I was waiting for a taxi outside my work building yesterday and i kept getting offered lifts by guys haha very flattering.
Maybe they thought you were still working . Bwahahahaha
Sorry loz , just joking but I couldn't resist.
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
nah i did two years of japanese got a lot of certificates too prove i learnt something in reality i didnt - two years after that i learnt that they have very nice cars that was about it!! Oh i learnt Mushi Mushi - haha i love that - oooh and some kinky japanese words i learnt while watching late night SBS once when i was a teenager haha
In reply to Joe - my jugs arent the big but my legs are mighty long :P
Ken - haha trust me i cant get "that kinda work" in a govt building - most of the guys are 50 an dstill live at home with mummy - i tell no lie!
Originally posted by aw11
wow a whole page and no animal sex. what are you people on tonight?
Keep up AW11 , we worked out it's pwptf who is the problem.
Wait till he comes back and then the animal will come out.lol
Cheers
Ken
yes i want to learn french too always have always will - but as far as turn on stakes cant go past a guys irish accent - yummy! I tell ya when the olympic games were on and they had the mastercard ad with the young irish lad mmmm for some reason i couldve taped that haha
your kidding aren't you.
They could be your best customers. Ask pwptf , he spends 1/2 his life near or in brothels
Cheers
Ken:D
ps He is so gonna get me when he logs on .hehehe
* looks for green suit and leprechauns *
be gosh and begorrah me daaarling .
Nah , that ain't gonna work.
ahhh well
Cheers
I tried
Ken
well gentleman bedtime for me gotta sleep off some of the champers!!
Ave a good day tommorrow!
Joe i'll try to rememeber to bring mobile to work tommorrow give ya a message round 5:30 see whats going on :P
****good night kisses to everyone****
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
