Hehehe , yea the subarus are a little weak in the gearbox area if mistreated ( ie. 6K clutch dumps )
The customers get upset when you tell there 3rd mod after a 3in pipe and clutch is a gearbox kit to make the rest of there mods stay together.
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
STI gearkits are stronger than stock and after that you start looking at dog gears , be it a full kit or just 1, 2 and 3.
PPG do a reasonably priced kit.
They do a dog kit for a GTR at $6300 plus forks $800 plus install.
Hmmmmm.
btw manifold is still leaking but will pull apart next week .
Bit of time b4 next comp day ( not like the 1 week gap this time:mad:
Cheers
Ken
Originally posted by GTS-t VSPEC
Yeah, I didn't realise this round was so soon.
Will you be going to the night master or the 4,6 and rotary?
I hope my Rb25 box will hold, can get expensive when you have to replace things like that.
See'ya:burnout:
will be flat out prepping 3 rally cars for end of March so doubt it.
Cheers and night
Ken
Yeah pretty good night, started in perth, then northbridge, then ended up in joondalup, but made it home so thats the main thing, im surprised i can still type properly.
are they the trial ones????
i have genuine NISMO 400R ones one my 'line and they have the little mesh bit towards the back end, but to tell ya the truth i wasnt really looking at skirts, cause i had them already, but there pretty good at WORKS so just pop in there and take a look im sure they will be able to sort out some good skirts for ya
troo troo
coz i saw some awesome skirts there last time
can't remember if it was 400r or trial
had like a lil triangle bit vent that was meshed on em ah well
must pop in and have look!
ah nice eventful nite? but joondalup? what the hell is in joondalup?
adrian :D
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
