Hehehe , yea the subarus are a little weak in the gearbox area if mistreated ( ie. 6K clutch dumps )
The customers get upset when you tell there 3rd mod after a 3in pipe and clutch is a gearbox kit to make the rest of there mods stay together.
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
STI gearkits are stronger than stock and after that you start looking at dog gears , be it a full kit or just 1, 2 and 3.
PPG do a reasonably priced kit.
They do a dog kit for a GTR at $6300 plus forks $800 plus install.
Hmmmmm.
btw manifold is still leaking but will pull apart next week .
Bit of time b4 next comp day ( not like the 1 week gap this time:mad:
Cheers
Ken
Originally posted by GTS-t VSPEC
Yeah, I didn't realise this round was so soon.
Will you be going to the night master or the 4,6 and rotary?
I hope my Rb25 box will hold, can get expensive when you have to replace things like that.
See'ya:burnout:
will be flat out prepping 3 rally cars for end of March so doubt it.
Cheers and night
Ken
Yeah pretty good night, started in perth, then northbridge, then ended up in joondalup, but made it home so thats the main thing, im surprised i can still type properly.
are they the trial ones????
i have genuine NISMO 400R ones one my 'line and they have the little mesh bit towards the back end, but to tell ya the truth i wasnt really looking at skirts, cause i had them already, but there pretty good at WORKS so just pop in there and take a look im sure they will be able to sort out some good skirts for ya
troo troo
coz i saw some awesome skirts there last time
can't remember if it was 400r or trial
had like a lil triangle bit vent that was meshed on em ah well
must pop in and have look!
ah nice eventful nite? but joondalup? what the hell is in joondalup?
adrian :D
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
