  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yes,
It's just like C++ or Visual Basic, but instead of text code you use objetcs, and you can build objetcs into more advanced structures. It comes with a large library of structures for doing quite complex task's, so developemnt time is reduced.
See'ya:burnout:
Enjoy your lunch. :D
Hmmm sounds like a very interesting package.... I did quite alot of C++ Programming and some PLC work back in TAFE, but that was about 4 Years ago now.... Thats why my questions are so vague... as is my memory :)
Oh well thanks for taking the time to answer/indulge my questions... I find it interesting....
I will do my best not to bother ya with any more silly Programing questions now :P
Chat to ya later :uh-huh:
abusive sms's from paul
what a life i leave
hehe, i have night shift dude so nothing to do till then.
besides i've already driven up to ossi park and back to get the clutch checked.
the vibration is virtually non existant anymore which is sweet.
Ross described as you lost some tractability down low with the lightened flywheel but will hae gained more up top
whatever that means
Haha.... Yeah now that you mention it I have always thought your face was familiar.... I just put it down to one of those faces that you think you know but you don't know.... :P
Yeah Geoff was really cool.... I knew him pretty well..... I think towards the end though he left as he was appointed to another position and was rarely at AMTC...
I am trying to remember the old guys name..... Ahh I cant think of it for the life of me!!!! Wasnt it Kim Gates or something???
I had him for several classes over the course of my studies there...
What course did you do there??? Was it an Electronic or a Computer Systems Diploma or something different???
Oh and Howard Baker!!!! He was so cool..... Hehe the way he said he couldnt get done for descrimination because he descriminated against everyone!!!!
Yeah you turned up... you passed..... Glad I didnt have him for any serious classes though!!!! Only ones like occupational health and safety and writing workplace documents and such!!!
yup kim gates was his name
Geoff got given an admin position at amtc when i was last there so his student contact dropped heaps
i did the associate diploma of computer systems engineering.
also did enough extra subjects to pick up the certificate 4 of electronic engineering.
now i just got to get off my arse and go ask for the bits of paper hehe.
Yeah the paperwork is kind of important!!!
We couldn't have been two far apart in the course then....
Alot of my mates from tafe ended up finding jobs at the end of the course, and to this day still have like 1 subject outstanding and the refuse to finish the course.... And we finished about 4 years ago!!!!
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
