  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
Wally llama Ken and his words of wisdom!
Private PM between sneeza and me.
So nyeh , nyeh:D :bahaha:
Oh shit , He's BAAAAAAACK
pwpt60secf.
And I see micko the slow reader is on. Gotta love 56K modem. It will take him all night to catch up . hehehe
Cheers
Ken
Originally posted by GTS-t VSPEC
Ken,
Were you just having a go at my staying power? I don't need pills to stand at attention:p
See'ya:burnout:
I may be a slow starter but once I get going.......
Cheers
Ken
Yeah, Micko is the voyeur, he likes to read, but not join in. I haven't bothered to read back yet, seeing as I wasn't here not much would have happened:p
See'ya:burnout:
Thats what you think.
Rooms booked , camera crew and backup is ready , just waiting for the Main Event.
Cheers
Not johnny Farnham again
Ken
I hope you didn't buy too much film:p
Your giving the hand a real workout?
Niz,
Just thinking of you makes the blood rush from my head:p
See'ya:burnout:
Yea niz , god never gave man enough to fill both.
Cheers
Ken
RSI ?? wouldn't waste it on the hand.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
