  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by adam 32
id still want to go for a more recognised brand ie K&N, Apexi, Blitz etc its an expensive mistake
a $30 filter could cause over $2000 of damage. it happened to macka 6 months ago
Don't know what it is with you guys and pods.
Have had 2 xR's with em on , took em off , put std box back in with K+N .
NO difference at all, well none you would notice on the road.
Cheers
Ken
Originally posted by GTS-t VSPEC
Keep Macka away from the car, he's nothing but bad news:p
Ken,
True, but I can shear off a sump plug:p
See'ya:burnout:
Sad part was , it wasn't the sump plug , just the aftermarket insert.
* hmmm , can't even recognise a sump plug *:P
Cheers
Ken
Adam,
Your still getting a workshop to replace the valve right?
See'ya:burnout:
Hope it is the valve and not just a lump of carbon stuck under the seat.
Adam will be pissed off .
Cheers
Ken
yeh
i got a headshop lined up for next week
unless its something rediculously simple like a bolt stuck in there in which case tristan should know what hes doing. well have to wait and see, should be a bit of a learning experience nontheless
If it's a bolt stuck in there , you are gonna NEED a headshop cos the valve will be bent , seat scored and hope it hasn't peppered the piston.
Cheers
Ken
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
