yeah i try to keep the crap in my car limited - if its not practical throw it out. My friends only hav ethe right to sit down and shut up in my car otherwise they get left on the side of the road - they respect that! I had one mate who was a little too vocal on the driving technique aghh i hate backseat drivers i nearly kicked him out on several occasions - if he doesnt like it he can drive his commonwhore!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
MMMM
Bonking techniques
* hay darl , come here , I wan't to try out something I learned *
Nope , didn't work. Still can't work em out.
I think Prank is after a stock one which leaves rice racer a bit out of it.
Cheers
Ken
Originally posted by GTS-t VSPEC
Hehe, I like your attitude Niz. Most of my passengers are too scared to talk:p
See'ya:burnout:
Ahhhh , I see..
So its
Get In
Sit Down
Shuttup
Hold onto this.
Ooooh , that's nice
Cheers
Ken
PS Page ownage hehehe
PPS RR ( Rice Racer ) has a 1/2 cage I think
oh my mum suffers from car sickness plus she drove my car while i was away - heard the turbo whizzing didn tknow what it was thought my car was sick hmmm - while my battery was flat on saturday i was drfiving her car everywhere (bloomin marlows three times befor ethey worked out what battery an R33 took then proceeded to bag imports in front of me) and for a 60,000 dollar car she got ripped take the line anyday instead of that thing hate driving it!!
I heard Wholagans car didn't last too long, the CDI packed it in.
See'ya:burnout:
Worked fine on the dyno I believe with 477 rwhp but in the heat of battle at the track started breaking down.
I believe Richard Aubert had better have some KY lube ready...
Cheers
Ken
*Note to self* No back seat Drving on Sunday :uh-huh: :P
cheers
Joe
i dont car who goes DJ in my car they only have a choice from my CD's anyway!! plus ive got a bit of everything so we can usually agree on something - hmmm but Joe's attempt at the Vengaboys in my car - not on!!
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
